SHELBY GT-500 Brakes
The Analog Admin!
Received 3,204 Likes
Warning ! Big Price Increase on 07 Shelby Brembo Brakes!
Hotsheets Updated! I knew this would Happen! They were Just too Cheap!
KC
KC
They won't fit behind the factory 18x8.5" wheels. There is not enough offset to clear the outside of the four-piston calipers. If you will look at your car now you will see that the wheels barely even clear the OE two-piston calipers, and those Brembo's are much, much wider (along with just about every other four-piston kit out there).
I wanted to do the same thing and I found this out, much to my disappointment
Is Ford purposely trying to PO those who want to modify their cars affordably? I guess anything associated with the GT500 will be expensive. Will there be dealer AMV's on the parts as well? What a bunch of .
The Analog Admin!
At Least you get the Strait Scoop from Yours truly and no AMV on My parts!
KC
KC
DerekShiekhi
GT350
9/29/15 04:35 AM
