SCT Xcalibrator "Reflash"
Old Mar 9, 2005 | 11:44 AM
HOTLAP's Avatar
For those of you who have reflashed your ECU with the SCT - was your stock tune still saved? ...i.e., the SCT will not pull the existing tune in and save it over the stock tune already saved on the SCT?
My CEL light tripped when I installed the Steeda ud pullies and it has not cleared after several ignition cycles....so I'm going to reflash to see if that will clear it.
Or would disconnecting the battery for a few minutes accomplish the same thing?
thx
Old Mar 9, 2005 | 12:13 PM
Purple Hayz's Avatar
I'd try the battery the first. Give the ECU a chance to reset and then see if the CEL comes back on after a few driving cycles.
Old Mar 9, 2005 | 12:42 PM
rhoover2's Avatar
The SCT will not write over the stock tune no mater how many times you load in the custom tunes. I would try the battery first also. When you first fire it up after the battery disconnect make sure you let it idle for a few minutes. I know I read that on a post here somewhere but I couldn't find it. Maybe you can..
Old Mar 9, 2005 | 01:16 PM
HOTLAP's Avatar
Thanks guys - I'll try the battery 1st - Ron good advice - the OM even has the procedure for "re-training" the ECU after disconnecting the battery.
Old Mar 9, 2005 | 06:17 PM
HOTLAP's Avatar
Just wanted to report back. I disconnected the battery for about an hour, reconnectd and the CEL is HISTORY!!
Thanks guys - :worship: :worship: I was going to go straight to the SCT reflash and didn't even need to!! If you are ever in the 1000 Oaks area - I owe you a cold one!
Old Mar 9, 2005 | 06:54 PM
acadian's Avatar
Even though I didn't read this in time to tell you about the battery dsconnect, congrats on getting that fixed. Can you tell a difference after installing the pulleys and having the computer recognize them?
trackpack13gt
Jul 25, 2017 05:29 PM
Antigini-GT/CS
Oct 5, 2015 09:43 AM
Glenn
Sep 23, 2015 08:37 AM
samjluck
Sep 17, 2015 10:24 PM
