Saleen Short Throw Shifter block installed (with pics & vid)
Old Sep 9, 2009 | 07:27 AM
  #61
Originally Posted by dsmdiggler
I didn't use a ton of loctite so hopefully the bolt and nut will stay put.
Back from the dead!
After a few hundred miles, poke your head under the car and check to make sure the nut is still secured and everything else looks okay. If that nut gets loose or falls off, you'll know it. It may not be a bad idea to get a spare one.
Old Sep 9, 2009 | 10:24 AM
  #62
dsmdiggler's Avatar
Originally Posted by TacoBill
Back from the dead!
I actually thought about getting another backup nut, I think I'll do that.. You wouldn't happen to know what size that nut is? I figured if anyone knows it would be you..
Old Sep 9, 2009 | 10:43 AM
  #63
Nope, sorry. I do believe that nut has an internal lock in it to help prevent it from backing out. Maybe the Dealer parts dept can help track it down.
Old Sep 9, 2009 | 11:44 AM
  #64
dsmdiggler's Avatar
I didn't quite pick up on the pun from my last post.. Nice...
Old Oct 21, 2024 | 02:39 PM
  #65
rocknrod's Avatar
Clean Machine Supercharged S-197 Member
Well I purchased one of these and tried to install it. I had previously installed a FPP one piece aluminum drive shaft that is larger around than the stock unit. It sticks down too far and wont shift. So I'm removing it here in a minute. One good thing is I turned around the little angle on the shift arm to it's toward me now. Also previously i installed the AMP bronze shifter bushing set, made a little difference. I tried.
Import-Slaya
90
Mar 4, 2006 07:14 AM
mustang196905
Nov 6, 2005 05:12 PM
phun-ky
Jul 29, 2005 09:26 PM
