Road Racers please help
Old Aug 7, 2007 | 05:34 AM
Tony Alonso's Avatar
Originally Posted by RedDragon777
Well not condoning this but since i bought the car i have been driving out at night through the outskirts of my town taking some of the hard turns at good speeds and have noticed that the car likes to roll a bit more and wants to break loose, i would like it a bit stiffer. I test drove a Shelby GT a while back and it took a while to get used to standard (since mine is an auto) but once i did my dealer friend let me take some hard corners to feel the FRPP suspension and i loved it, took corners alot better and i felt more in control, that is why i am thinking about doing the sway bars after the brake pads and lines
Tires will help with the grip situation. An FRPP suspension is nice but it comes at the expense of a firmer ride that you may or may not find acceptable if you daily drive your car.
I was also thinking about the watts link but the set up alone is about the same price as all the suspension peices without the PH bar and the support, and is there a big difference between PH bar set up and Watts link setup
I would love to hear other people's opinions on the Watts linkage for a road racer. I have thought about doing this to my daily driver to settle the rear end over bumpy surfaces in my daily driving. I have wondered about its merits on road courses, where the surfaces are generally smooth.
I like the Watts linkage!
Old Aug 8, 2007 | 02:12 AM
RedDragon777's Avatar
well first things first i am going to buy a helmet, i will look around for one, but i am liking the Diamondback from Simpson, i see this as a long term investment
Old Aug 8, 2007 | 11:15 AM
RobK's Avatar
I test drove a Shelby GT a while back and it took a while to get used to standard (since mine is an auto)...
If it's an auto, add a trans cooler. Autos don't like spending much time on track. They don't get enough sustained speed to cool effectively with the stock cooler.
Old Aug 8, 2007 | 05:14 PM
what cooler do you recommend, i was looking into the B&M trans cooler
Old Aug 8, 2007 | 07:32 PM
RobK's Avatar
ANYTHING is better than nothing. The B&M should be fine. Heat is an auto tranny's worst enemy.
Old Aug 9, 2007 | 10:16 AM
mot250's Avatar
Originally Posted by Import-Slaya
You should also look up the NASA chapter in your region. They put on some very well run, safe, and reasonably priced weekend driver events.
All you need to get started is a helmet. Highly recommended is a set of better brake pads and a full brake fluid flush. Do not use a silicone based fluid. Among other negatives, it is not compatible with DOT3/4 fluids, and may not be compatible with the seals in our system. Use a good high performance fluid, such as Motul-600, ATE Super Blue, Valvoline Synpower, etc...
No need for a big brake kit (unless you have money to burn and want the bling factor) at this stage in the game--our calipers are actually pretty decent from the factory, but the pads are useless. Put your money towards a decent set of track pads and stainless lines. If you have more in the budget, get some springs/struts/swaybars. Once you have a few events under your belt, get some stickier tires than the stockers and wider/lighter wheels.
Agree. These S197s are very good on a road coarse in stock dress (brake pads excluded) and can outperform or at least hang in with earlier Mustang models already using a multitude of braking and suspension mods/upgrades and even engine/power upgrades! Upgrades to our cars in suspension (springs/ struts/ shocks) will make the car feel better on the track but, until you move up to better tires, the gains of an upgraded suspension will be hard to realize in quicker track times.
In short, you can spend as much or as little $ as you want. Your only necessary spends will be on helmet, track fees (highly recommended to consider including time with an instructor which may be included in certain events) and brake pads (whether you use multiple stock replacement pads or upgrade to a pad capable of handling track usage). BTW, if you experience brake fade, you boiled probably also your fluid and should re-bleed the brakes to gain the pedal feel back before going back out ont the track. So maybe add the expense of a bottle or two of brake fluid for bleeding
Unfortunately, after the first experience, you will be smitten and will have the urge to spend more time and money preparing yourself and your car for future events.
Enjoy!
Old Aug 9, 2007 | 10:39 AM
Mystic_Cobra's Avatar
upgrade the driver first, the car second
As someone who has been doing road course track events for about 7 years, I can agree with this post. NASA has a great program for beginners. The HPDE (high performance driving event) program is ideal for someone like you. Don't start upgrading the car. It's best to learn with a nearly stock car. You DO NOT need ANY brake kit for your car until you have several events under your belt. You DO NEED to have a helmet (SNELL SA-2000 or newer) and be able to pass a typical state safety inspection. Make sure you bleed the brakes and have at least 50% of the pads left for any event like this.
There's all kinds of info (plus the forums) at www.nasaproracing.com on the HDPE program.
I race my 96 Cobra in NASA's American Iron program after running HPDE events for about 5 years. It's a blast! SCCA is cool too, but no one runs events like NASA and the rules (for Mustangs, at least) are way to strict in SCCA compared to NASA. Another reason to NOT modify your car...if you start racing or Time Trials or Solo (auto crossing) you can get bumped up to a class where you can't run competitively for too many mods.
Old Aug 10, 2007 | 12:17 AM
Well to get started i ordered a Simpson Voyager helmet, and that should be in soon. As soon as my next pay check comes in i will be ordering some Hawk HPS pads, also i will be adding some Earl SS braided brakelines (unless there is something better) and some Granatelli rotors and i will leave the car at that till i have a few events under my belt. Still need to find out what my local auto stores have for brake fluid, going to need alot if i am going to flush the system
Old Aug 10, 2007 | 11:51 AM
Stoenr's Avatar
You're gonna be addicted!
Its fun.
All Ive done is HPs brake pads, stainless lines, better brake fluid.
Better tires. Few other mods, but I didnt do them for road course events.
Best thing is get a ride with an instructer, you will learn ALOT!
I have some videos of this years event. It rained all freakin day, made for some good fish tails.
3,4 have more sliding.
In car camera
1 http://www.youtube.com/watch?v=N2RGOuVDndY
2 http://www.youtube.com/watch?v=91K5YdjergM
3 http://www.youtube.com/watch?v=XjVhqHazCtM
4 http://www.youtube.com/watch?v=BclKOxUSChQ
Outside cam http://www.youtube.com/watch?v=lxLVXC7wNgs
Old Aug 10, 2007 | 12:06 PM
dang man, love seeing that thing go down the track, what brake lines did you use, i want to go with Earls but only becuase of the cost but i know the idea of "you get what you paid for" i was also thinking about Russell brake lines
Old Aug 10, 2007 | 12:46 PM
StillenMustang07's Avatar
Authorized Advertiser
Everyone is on the money suggesting the brake upgrades. If you plan on participating heavily in various road coarse events I would suggest a big brake kit. However, if the pocket book doesn’t permit such a purchase then upgrade the rotors, pads, lines and fluid. For rotors I would go with DBA 4000 series (most durable 1-piece rotor available), Hawk or Pagid brake pads, Goodridge lines, and Motul RBF600 fluid. Also a duct kit will help to regulate brake temps.
Have fun!!!!!!!!
Old Aug 11, 2007 | 02:05 AM
fastduo's Avatar
I prefer HP+ pads and not HPS pads. Hp+ pads are a bit more agressive and won't fade as easily if you get them hot. If you are handy with tools, swap out the HP+ pads and put your stock ones back in for the street.
HP+ pads are noisy and will get your wheels dirty on the street but do well for track duty. Plus the HP+ pads will last longer if you don't use them for the street. It takes a very short time to swap them, once you get the hang of it.
You can buy the caliper tool you'll need for cheap from Harbor freight.
Link: http://www.harborfreight.com/cpi/cta...emnumber=40732
Old Aug 11, 2007 | 08:28 PM
shaun_beauchamp's Avatar
YES, the track in my vid is Road America. NorthWest Shelby club has an annual August Track Day and you're invited. Let me know when you'll be in WI and I'll set you up with the contacts and the agenda for everything.
I have corporate room rates available for hotels in the area. I have all my tools and I'm willing to assist anyone who wants to join in the fun.
I will spectate this year as I just ran out of finances for summer fun. We had a great time doing the Power Tour and other events this year, but next year I'm back to the track.
Later,
Shaun
Old Aug 11, 2007 | 10:08 PM
well i should have the brakes upgraded and my helmet in, what day in august, i am not worried about hotels since my girls parents live in cascade. How much was it for the event, so i can have an idea for my budget.i am planning on being up there for towards the end of july but if the event is more towards the middle of august i will pull back the trip a bit.
Old Aug 12, 2007 | 06:42 AM
Import-Slaya's Avatar
Save some money and don't get the rotors. They won't do anything noticable for your braking performance.
Old Aug 12, 2007 | 10:23 AM
JonW's Avatar
Fastduo, when you're swapping your brake pads back and forth like that, do you need to re-bed them each time?
Old Aug 12, 2007 | 11:33 AM
GPStang06's Avatar
Just went down to the Homestead event yesturday (wish I could have made today as well). Everyone is spot on here. You are getting your helmet and once you have it go to the track and learn first. Look around at the other cars there as well, you will see full blown cars with cages to stock rides like the Chrysler 300 that looked like it just rolled off the showroom I watched yesturday.
And be careful, if you thought drag racing was addicting, you are about to be a full blown addict. I have the itch again...badly!
Old Aug 12, 2007 | 01:21 PM
i had the idea, then i read somewhere that the rotors help with pad wear since it keeps the pad temp lower then if i kept the stock rotors, but for sure i know i am going to flush the brake fluid and add something better, also add SS brakelines, and Hawk HPS (only reason is because i do not want to deal with dust and having to swap them out before i go home, once i buy some cheap black wheels and have learned a bit more i will more than likely swap to HP+ but for now i need my fanblads fairly clean since this car sees alot of car shows and soon SOME track time {{i hate that we only have a seasonal track run}} )
Also anyone know a site that sells good brake fluid like motul-600 or something better, alot of the shops down here do not carry it, also what are your recommendations for SS brakelines, i was looking at earls but i have seen the russell and goodrich at a fair price and wondering what i should go with. I also like the stoptech ones but the front lines alone cost as much as the russell KIT. Brenspeed has a good deal on the stoptech lines, Motul fluid, and pads but i would like hawk pads and i do not know if the three bottles of fluid are enough to flush the whole system.
Old Aug 12, 2007 | 02:51 PM
Stoenr's Avatar
...Hawk HPS (only reason is because i do not want to deal with dust ......
Hehe, you have no choice but to deal with the dust
pic taken after road course event on HPS pads.
Brenspeed use to include the Hawk pads I thought. Hmm.
I got everything from different suppliers, Stoptech lines, brake fluid, brake pads. Dont have links to where I got them tho. Nor remember. It was a panic to get all the stuff before the event.
Dont worry, they clean up well.
But expect to clean them after 2 days of ordinary driving around town if you want to keep them spotless.
Old Aug 12, 2007 | 02:58 PM
  #40
that is ok because i have a pressure washer at home but i know the HP+ will look ALOT worse, my friend uses the REAL road race pads (the ones used just for road racing and not meant for DD use) that he ordered from Hawk on his T/A and he had some cheap silver wheels and when he was done i could have sworn he got them powdercoated black sometime in the middle of the day. Brenspeed used to sell Hawk pads but they swapped to a different company, hopefully RotorPro still sells Hawk pads for the price they gave me
