Rim size for drag racing
Old May 24, 2011 | 08:49 AM
Victorfriessen's Avatar
Im having the idea that changing tire size gives the same effect then changin gear ratio,what rim size with what tire size would give the best result for drag racing in 1/8 mile?and to what gear ratio would that size be compared to?
Old May 26, 2011 | 09:16 AM
socalwrench's Avatar
The factory GT tire is probably 27" tall and uses 3.31 gears. If you were to run a tire smaller in diameter, that would be similar to the running a higher numerically rear gear ratio. If my math is correct, you'd get a little bit of benefit. Essentially, going from a 27" to a 25" tall tire would be similar to going from 3.31 to 3.55 gears.
The 1/8 mile is relatively short, and you'll need as much off the line acceleration as you can get. If the car is going to be used primarily for drag racing, and not much cruising, I would run 4.56 gears. However, if you still are going to drive it on the street and drag race, I would run 4.10 gears.
Detroit Steel
Aug 21, 2015 11:09 AM
cloud9
GT350
Aug 18, 2015 01:34 PM
ClayP
Aug 3, 2015 09:00 PM
roushcollection
Jul 28, 2015 02:08 PM
BentCopper
Jul 21, 2015 08:35 PM
