Review: Steeda Under Pullies
Old Dec 10, 2004 | 06:15 AM
  #61
bullittman's Avatar
Originally posted by FordRacing@December 9, 2004, 6:13 AM
Now having said all this I believe that the Steeda sets are a quality built unit and you’re probably fine installing them. But knowing the weight difference between the stock units and the ones from Steeda would be interesting.
I'm installing the Steeda set this weekend. I'll check the weight diff.
Old Dec 10, 2004 | 08:04 AM
  #62
2005RedGT's Avatar
Originally posted by bullittman+December 10, 2004, 7:18 AM--></div><table border='0' align='center' width='95%' cellpadding='3' cellspacing='1'><tr><td>QUOTE (bullittman @ December 10, 2004, 7:18 AM)</td></tr><tr><td id='QUOTE'> <!--QuoteBegin-FordRacing@December 9, 2004, 6:13 AM
I'm installing the Steeda set this weekend. I'll check the weight diff. [/b][/quote]
w00t! When you get those numbers, mind if I post them on my website ?
Old Dec 10, 2004 | 08:38 AM
  #63
bullittman's Avatar
No problem! Some partial #'s stock vs Steeda.
Harmonic balancer- Steeda- 6# 3 oz. 5.2 inches OD
Stock 7.475 OD, 9#
Water pump pulley -Steeda 6.43" Stock 5.1" Steeda is marginally heavier
Old Dec 11, 2004 | 09:24 AM
  #64
bullittman's Avatar
I finished the Steeda pulley job this AM..... A couple of notes for those who haven't done this before . You will need to pull the fan for clearance, and you will need a GOOD quality 3 prong puller. I borrowed one from my local mechanic and it worked well. It was for Mopars. Other than that it was straightforward, GOOD luck! B) (I put some notes about weights and dia. comparisons in post above for reference).
Old Dec 11, 2004 | 09:31 AM
  #65
swingle007's Avatar
Ditto on the need to pull the fan and have a strong puller. My local shop installed mine last evening...Only took about an hour and 15 minutes but required a bit more effort then first thought. They made a noticeable difference. I can feel the extra power in second gear more then any other. Pulls much harder. Good power for the investment!
Old Dec 11, 2004 | 09:38 AM
  #66
2005RedGT's Avatar
Fantastic, also thanks for the stats as well.
Old Dec 11, 2004 | 10:42 AM
  #67
bullittman's Avatar
No problem.....THANKS for your excellant site! B)
Sep 30, 2015 07:02 PM
GeoWett
Sep 30, 2015 06:40 AM
Sep 24, 2015 08:15 PM
Sep 16, 2015 06:44 PM
Sep 10, 2015 12:44 PM
