remove steeda pully
how do you get the lower steeda pully back off?
on the steeda pulley for the anchor, had to put the crank bolt in , to be used as a stop. i do remember getting the tool at autozone loan-a-tool. fairly easy, good luck.
there are 3 bolt holes on the steeda pulley, and no i dont remember the size,and i just used a harmonic balancer pully to pull it of.used the steeda longer bolt to put the stock pulley on.yes,a bought a saleen super charger.
Now I know I'm missing something. The Steeda pulley I installed used a factory ford bolt, just like the one I pulled out of the stock pulley. Where are you seeing the other two???
the 3 bolts thread through the puller into the holes in the balancer to pull the pulley off.there is a bolt a little lomger than stock to pull the stock pulley back on part way until you can use the stock bolt to pull it the rest of the way on.get a small mirrow and look on the pulley and you will see the 3 bolt holes.and i think they are metric.i had the same problem seeing them also.
9/24/15 08:15 PM
9/10/15 12:44 PM
