Rear sway bar
Old Sep 5, 2006 | 06:37 AM
TakeOffStang's Avatar
Rear sway bar
Anybody tell me the difference in the rear sway bar for a vert and coupe on an 06 GT. FORD lists two different #'s for this.
Old Sep 5, 2006 | 06:42 AM
clintoris's Avatar
convertibles typically have different springs and swar bars, 'cause they bare more weight. I can't say if the rear springs are different part numbers from the factory, but they typically are for aftermarket. A lot of people will go with convertible springs on their coupes, because it levels the car a little better... so the *** doesn't droop
Old Sep 5, 2006 | 06:48 AM
There is not a difference in the spring listing, just the rear sway bar.? Wonder what the diff is? The diameter or design?
Old Sep 7, 2006 | 08:34 AM
bump.
Old Sep 7, 2006 | 03:04 PM
Wolfmeat's Avatar
Swaybar Difference
I believe that the vert gets an 18 mm and the coupe a 20 mm swaybar. This is from memory and someone else may want to chime in.
robjh22
Dec 14, 2015 08:41 AM
Sep 16, 2015 06:44 PM
robjh22
Sep 8, 2015 12:31 PM
earl610
Sep 6, 2015 05:48 PM
