Rear spoiler removal
Old 4/12/07 | 11:08 AM
boss 302's Avatar
any tips on how to remove the stock spoiler? I know theres 4 bolts to remove but what is an easy way to separate the 2 sided tape? Thanks
Old 4/12/07 | 11:51 AM
RobK's Avatar
Fishing line tied between two "handles". Consistent, steady sawing action will go right through the adhesive. Follow-up with solvent to remove any glue that remains or heat with hair drier or heat gun on low setting and rub it with your finger. It will "ball" up and come off.
Old 4/12/07 | 06:42 PM
blkstang06's Avatar
Thats the ticket!!
Old 4/12/07 | 09:00 PM
mike05gt's Avatar
Smart man , my neigbor and myself used the brute force method
Old 4/12/07 | 11:05 PM
chris_fowler99's Avatar
I just pulled...it came off easy.
Old 4/13/07 | 09:09 AM
NJJOE's Avatar
I heated the the tape with a hair dryer after the boltes were removed and it lifted right off, not much force needed. Then just like stated before heated the leftover tape and it came right off the hood.
Old 4/13/07 | 10:39 AM
Lowe!'s Avatar
Hair dryer, a little force, and an exacto blade to slice thru a little of the tape, no problem. Goo gone or Goof Off, the one safe for paint, worked well getting all the adhesive off.
Old 4/14/07 | 06:51 AM
Mach's Avatar
Exacto Knives and body paint don't play well together.
Use braided fishing line, as stated above, like Spiderwire and saw through it. I didn't use heat on the left over glue and it took quite a bit of cleaning to remove the remains.
Attached Thumbnails Rear spoiler removal-p0000006a.jpg   Rear spoiler removal-p0000007a.jpg
Mpaps
10/11/17 09:06 PM
Fords4Ever
10/30/15 10:07 PM
dblhelx
10/6/15 09:08 PM
seaclam
9/25/15 02:29 PM
9/8/15 11:45 AM
