Rear o2 sensors
Old May 3, 2005 | 10:28 PM
Fman67's Avatar
Question...with an offroad exhaust,would there be any gain in turning off rear o2 sensors. Predator allows you to do this,just wondered if it would help boost power?
Old May 3, 2005 | 10:33 PM
Vegasjay's Avatar
No gain, it just keep's the CEL off.
Old May 3, 2005 | 10:43 PM
O5GT's Avatar
will the predator do this now?
Old May 4, 2005 | 04:39 AM
MTAS's Avatar
Does the 05 even have rear O2 sensors? If memory serves (I was just under the car this past weekend), there are only 2 O2 sensors, each of them plugged right into the middle of each cat. I could be wrong though.
Old May 4, 2005 | 01:36 PM
I8URVTEC's Avatar
I would consider those rear...there are more O2 sensors ahead of the ones in the cats. I took them all out when I changed over to Bassani cats. On the driver side the first sensor is on the manifold itself and doesn't need to be removed. The first O2 sensor on the passenger side is located just after the manifold but before the stock cats.
Old May 4, 2005 | 05:44 PM
Fman67's Avatar
There are two above also...one in exhaust manifold,other at top of h-pipe.
Old May 4, 2005 | 08:54 PM
169stang's Avatar
I HAD to turn my rear o2's off to keep the CEL off. I have SCT though.
Old May 4, 2005 | 09:44 PM
Wookdawg's Avatar
Those are just catalyst efficiency o2 sensors. No affect on fuel metering. Just light up the CEL when your cats go bad.
Old May 5, 2005 | 07:27 PM
Bullitt1609's Avatar
So if I was to replace my factory H-pipe with Bassani's full x-pipe with removable cats, there would be a good chance that my check engine light would come on?
I don't want to have to buy a tuner if I'm replacing the h-pipe.
kponypower
Jun 17, 2020 07:17 AM
trackpack13gt
Jul 25, 2017 05:29 PM
Evil_Capri
Sep 25, 2015 12:56 PM
