Rear Caliper ?
Old Sep 16, 2009 | 11:56 PM
Cobrakev's Avatar
Rear Caliper ?
When installing the new brake pads, which way do you turn the piston? Clockwise or counter clockwise? The reason I ask, is that it seems the piston will go in no matter which way you turn the piston.
Old Sep 17, 2009 | 12:09 PM
MTAS's Avatar
Clockwise, and it takes a lot of force - or at least mine did. But it will turn.
Old Sep 17, 2009 | 12:38 PM
07S197's Avatar
Swamp Donkey Man Cans
Push and turn at the same time.
If you are using that little block type adapter you get a Autozone, see if you can find the clamp style with the dies.
That one seems to work much better and you won't slip off the piston and crush a finger or dust boot.
Old Sep 19, 2009 | 04:41 AM
GT John's Avatar
The best way we have found is to put a "C" clamp on the piston to kinda break it loose a little and then use the block..........turns real easy then.
Oh yeah. don't forget to take the cap off of the brake fluid reservoir before you start.
Rando
Aug 25, 2021 11:12 AM
kponypower
Jun 17, 2020 07:17 AM
joemad59
Dec 30, 2015 06:13 PM
Christopher Fox Wallace
Sep 26, 2015 11:55 AM
Evil_Capri
Sep 25, 2015 12:56 PM
