Re-Oiling The Air Intake Filter
Old Apr 22, 2006 | 11:01 PM
Jon_Purdy's Avatar
How often should the air intake filter be re-oiled?
Jon
Old Apr 23, 2006 | 03:33 AM
stkdidy's Avatar
officially it only needs to be done every 20k or more miles. but if you drive it hard or alot or in dirty areas, every 10k would be a good idea. im no expert tho, just my opinion
Old Apr 23, 2006 | 05:56 AM
Patience's Avatar
i drive mine year round and in michigan winters, salt, constant road construction, etc----i am going to shoot for every 10-12 K as well---i would say depends on climate---
Old Apr 26, 2006 | 06:07 PM
Mxyzptlk's Avatar
I did mine at 8K but I probably should have waited longer, on the regharger kit it says that the dirt actually helps in the filtering.
Old Apr 27, 2006 | 04:04 PM
stkdidy's Avatar
<div class='quotetop'>QUOTE(Mxyzptlk @ April 26, 2006, 5:10 PM) Quoted post</div><div class='quotemain'>
[/b][/quote]
helps filter, but restricts air...big NO-NO [img]style_emoticons/<#EMO_DIR#>/nono.gif[/img]
Old May 1, 2006 | 10:31 AM
Patience's Avatar
<div class='quotetop'>QUOTE(stkdidy @ April 27, 2006, 4:07 PM) Quoted post</div><div class='quotemain'>
[/b][/quote]
very easy to clean---tapped out the dirt and loosened with soft bristle paint brush---applied cleaner for twenty minutes---rinsed with tap--boy oh boy---that thing filters out some serious grime! made sure to fully dry filter using fan----reapplied oil---walla! she sounds meaner this morning! [img]style_emoticons/<#EMO_DIR#>/thumb.gif[/img]
Old May 1, 2006 | 10:36 AM
dustindu4's Avatar
9 is not my lucky number.
make sure you hose it with water from the inside out, no focused spray either
Don't put too much oil on because it will coat your MAF sensor
Old May 1, 2006 | 11:03 AM
My Blue Heaven's Avatar
Reading the K&N web site it'll work fine up to 1/16", 1/8"? inch of dirt on it, and doesn't affect the air flow, actually helps straighten it. So they say.
May 3, 2026 05:42 AM
MustangConvert11
Sep 30, 2015 08:01 PM
exgto
2012-2013 BOSS 302
Sep 28, 2015 07:39 PM
southern stang
Sep 26, 2015 04:19 PM
