Pypes Mid-muffler system installed!
Old Dec 3, 2007 | 05:54 PM
Embalmer's Avatar
Got it from Brenspeed.com - as always excellent service. It was at my door 36 hours after I placed the order. I installed it in the garage using jackstands and ramps, but I had my local service shop tweak the pipes and clamps for me. Here are some pics of the exhaust installed. I'm gonna get some video but you really need to hear it under throttle between 3 and 6 K! Music from the gods!
Old Dec 3, 2007 | 05:59 PM
aircare84's Avatar
Looks like your local shop did a good job aligning.I tweaked on mine on & off for 2wks before I got it where I was satisfied. Good tone, I really enjoy the sound when shifting. Installing L/T's & O/R H this weekend,we'll see how loud it is then!
Old Dec 3, 2007 | 06:05 PM
colbymh's Avatar
looks sweet man..now fire it up so we can hear
Old Dec 3, 2007 | 09:27 PM
DarkFireGT's Avatar
Definitely want to hear some feedback (and soundclips) of that!
Old Dec 3, 2007 | 10:12 PM
07alloygt's Avatar
Yeah I hear with a stock mid pipe that the mid-muffler system sounds bad ***!
Old Dec 3, 2007 | 10:16 PM
Embalmer's Avatar
I'll get a sound clip tomorrow. I'm already looking into headers and an offroad H-pipe. She sounds awesome but I could stand a bit more raucousness!
Old Dec 3, 2007 | 10:18 PM
05GT-O.C.D.'s Avatar
I lust for a M24
What all is involved in the 'tweaking' of this system? I've been extremely interested in this setup, but the fitment issues worry me.
Old Dec 3, 2007 | 10:19 PM
dustindu4's Avatar
9 is not my lucky number.
those mufflers are scary close to those gas tanks!!!
Old Dec 3, 2007 | 10:36 PM
Embalmer's Avatar
You can get your hand up and around the mufflers and the tank has a thick plastic shield between it and the exhaust. The mufflers are a straight through design so they dont get very hot.
05GT - The system fit together just fine, but since there are so many pieces if you have one off just a little, the next one will be off more, etc. I basically removed the old parts, installed the new ones and clamped them together and took it in. He loosened all the clamps, rotated some of the pieces, moved the drivers side "tail pipe" out and tightened down the clamps. Plenty of clearance now.
Old Dec 4, 2007 | 04:47 AM
aircare84's Avatar
Here's a clip I made of mine a while back, stock H with factory cats;
http://www.youtube.com/watch?v=fANDdIp2GjY
Old Dec 6, 2007 | 03:38 PM
scramblr's Avatar
Those sound pretty d@mn good. I bet they sound mean with a set of headers.
Old Dec 6, 2007 | 04:22 PM
aircare84's Avatar
I'll be installing my L/T's on Saturday,I'll post some vids after the install. Probably be a little too loud for me then,still have my factory over-axle pipes & GTA's in case.
Old Dec 6, 2007 | 04:31 PM
officespace56's Avatar
So are you going to be keepin the pypes system on with the LTs and H? I assume you will be cutting the pypes system to fit with the longtubes and h.
Old Dec 6, 2007 | 04:50 PM
70MACH1OWNER's Avatar
Hey Larry,
I don't think I have ever seen anyone else that was running LT's and the Pypes system. You may be the first! We will take a before and after vid so everyone can see the difference. I am predicting very mean sounding and very loud!!! You may have neighbor issues though.
Scott
Old Dec 6, 2007 | 05:45 PM
tom281's Avatar
Shoot, with you two old farts doing the install, the volume may be just about perfect...... you know, that way you won't have to wear your hearing aids.
Old Dec 6, 2007 | 05:52 PM
Old Dec 6, 2007 | 05:59 PM
Boltzman's Avatar
Awesome.except for the freakin blinker sound
Old Dec 6, 2007 | 07:04 PM
aircare84's Avatar
Tom,
With my hearing loss after 30yrs of working around aircraft,you may be right
Actually, the Pypes mid-muffler setup is about loud enough for me now.Am sure it'll be quite a step up with the L/T's & no cats.
officespace,
I'll be running the L/T's with the Pypes system,if it's too loud for me, I'll reinstall the GTA's I had on previously.And the L/T's I have will be a direct bolt-up to the mid-muffler system,as they come with a straight H & an H with resonators.
Scott,
We will have to make sure we get the vids & post up here.
Old Dec 6, 2007 | 07:20 PM
ren274u's Avatar
any drone with this system?? if so how does it compare to the stingers?
Old Dec 6, 2007 | 09:18 PM
Sounds like a good plan. Let me know if you put the GTA's on with the LT's (soundclip maybe??) I have been lookin all over for a clip of LT's with the GTA's. Good Luck!
