Proper Oil fro 4.6L?
Old Apr 14, 2006 | 05:39 PM
Ugabulldog83's Avatar
Thumbs up
Folks,
Taking my GT Convt in for service next Friday. Its almost been a year and only 2800 miles [img]style_emoticons/<#EMO_DIR#>/banana.gif[/img] , well I was deployed for 6 months and just got back. What is the best oil to put in after the break-in oil? Will prob not go with a synth oil. Want to get the best oil [img]style_emoticons/<#EMO_DIR#>/dunno.gif[/img] for my GT. Thanks for any help!
Ugabulldog83
Old Apr 14, 2006 | 05:46 PM
freebass55's Avatar
Why not synthetic?
Old Apr 14, 2006 | 07:42 PM
Bingo's Avatar
Motorcraft. *shrug*
All you guys are all about your $10 per quart synthetics...Motorcraft synthetic blend is just fine, at least as far as I'm concerned. BTW, just changed it not too long ago at 2100 miles.
Old Apr 14, 2006 | 08:20 PM
GRAYPNY's Avatar
Mobil One 5-20w synthetic~
Old Apr 15, 2006 | 03:45 AM
My reason for not wanting to go with a synth is that I may not always be able to find the synth oils where I am, and once you use it, start using a synth in the engine you can't use an organic oil, correct? I think overall that the organic oil is the safer way for me to go.
Ugabulldog83
Old Apr 17, 2006 | 03:31 AM
Indystang's Avatar
Well I would say just use the best oil you can get on a regular basis and change it regularly. Don't let the oil sit in there for extended periods of time. Even if you don't drive it, I would change it before it sits again. I have read that about 4 months and you should get the oil changed. Very nice looking Vert too Mike [img]style_emoticons/<#EMO_DIR#>/thumb.gif[/img]
Old Apr 17, 2006 | 09:38 AM
Old Mustang Guy's Avatar
There is not a problem with switching back and forth between synthetic and mineral oil, however, the Motorcraft syn blend 5W20 is an excellent oil and a good value. It is produced by Conoco Phillips and is about 50% group 3 sythethic.
Old Apr 17, 2006 | 09:51 AM
mudshuvel319's Avatar
by the way, synthetic oil is not that expensive. it's pricier than non-synthetic or blend, but i just changed my oil and used synthetic. for 6 quarts of mobil 1 10w-30 and a fram filter, i paid less then $30. just look around a little for a good deal. if i went to my local pep boys, i would have paid al least $10 more.
Old Apr 17, 2006 | 09:52 AM
Rebel73's Avatar
Ditto on the Mobil 1 !!!!!!! And yes, it's ok to switch back and forth...
Since we're on the subject, guys, what about MIXING regular and synthetic? Can you do that?
Old Apr 17, 2006 | 01:29 PM
Shifter1's Avatar
If you have the car in Germany, ask Ford what they recommend for use in Europe, including on autobahns. In Australia, I'm sure they will recommend a 5W-40 synthetic for their roads and climate, which Ford's 5.4-litre modular Falcon's come with from the factory.
In the US, Ford recommends a 5W-20 and Motorcraft's (Ford's) is probably the best Synthetic Blend oil there is.
In any case, I would go several more oil changes on Synthetic Blend before switching to pure Synthetic.
Old Apr 17, 2006 | 10:12 PM
slammer223's Avatar
Welcome back from your deployment. Thanks for your service!
I went with Motorcraft synth. blend first change then went to Mobil 1.
Old Apr 18, 2006 | 03:28 PM
70MACH1OWNER's Avatar
<div class='quotetop'>QUOTE(GRAYPNY @ April 14, 2006, 9:23 PM) Quoted post</div><div class='quotemain'>
[/b][/quote]
+1 good stuff and can be found everywhere!! [img]style_emoticons/<#EMO_DIR#>/thumb.gif[/img]
Old Apr 19, 2006 | 05:30 PM
Patience's Avatar
Mobil 1 synthetic...period
Old Apr 19, 2006 | 05:40 PM
OKCMustangGT's Avatar
Exactly what I did.
Old Apr 20, 2006 | 01:59 AM
harry.l.toomey's Avatar
Royal Purple 5w20. [img]style_emoticons/<#EMO_DIR#>/thumb.gif[/img]
Old Apr 20, 2006 | 01:00 PM
I could not find Mobil 1 5-20 Syn here. So I brought Castrol 5-20 Syn for the oil change and a stock Ford filter for the 4.6L. Thanks for the guidance and help.
Ugabulldog83
Old Apr 21, 2006 | 12:33 AM
Indystang's Avatar
Castrol Syntec isn't pure synthetic motor oil, just in case you didn't know. I used to use it all the time too but not anymore. I think someone on here linked to a couple of sites that talked about the different kinds of oil ingredients, base stock, etc.... Very interesting reading too.
Old May 1, 2006 | 05:18 PM
Reminisce's Avatar
That brings up a slightly off topic question.
When I bought my GT, long story short, they threw in a deal for 6yrs 60000 mile free oil change. Any idea if they will honor using Mo1 Synthetic?
Old May 23, 2006 | 08:25 AM
Firedude's Avatar
Synthetic. Your car is worth it.
Old May 23, 2006 | 08:27 AM
Galaxie's Avatar
I Have Admin Envy
I'm guessing you'll have to pay extra for the synthetic. I believe its worth it.
My mother's car has been running mobil1 since the engine was broken in. If and when that car dies, I would love to pull the motor and inspect it for wear
