Pro 5.0 Shifter versus?
Old Apr 21, 2008 | 10:24 PM
muslenutz's Avatar
So I drove my buddies mustang today after he installed a PRO 5.0 Short throw shifter. Wow, what sweet shifts... As I will probally buy this one as I really liked it, can anyone tell if there is a mjor difference between any other brands? I see alot of people talking about MGW and Hurst. ANy help would be appreciated.
Old Apr 22, 2008 | 05:35 AM
tom281's Avatar
Don't mean to sound rude, but search the forums....... there is TONS of info here about both shifters, including a couple of threads specifically about the Pro50 and MGW head-to-head.
Old Apr 22, 2008 | 03:13 PM
302svt's Avatar
I have the Pro 5.0 and I like it alot, a little hard to get into 5th and Reverve but that should get easier the more I use it. The new Hurst Billet Shifter looks like it is well made.
Old Apr 22, 2008 | 03:52 PM
blak05's Avatar
I have the MGW and love it..build quality is really unreal, thing looks like it was built for a jet..before you buy have a look at them..customer service was really good as well and made for a great buying experience..fully adjustable in throw and **** height as well
Old Apr 22, 2008 | 03:58 PM
muslenutz's Avatar
what keywords do I search, when I do it... it states words must be longer?
Old Apr 22, 2008 | 05:38 PM
tom281's Avatar
searched, and found these:
http://forums.bradbarnett.net/showth...=pro50+shifter
Keep in mind as you're reading that the Pro50 and Steeda Triax are very, very similar.... so comments about the Steeda can/will apply towards the Pro50 too.
Old Apr 22, 2008 | 06:49 PM
GRAYPNY's Avatar
You will find that when it comes to shifters it's pretty subjective. People love their Hurst's, Pro5.0's and the MGW. I personally have the Pro5.0 and like it, but if I was going to buy a shifter "now" it would probably be the MGW.
Old Apr 23, 2008 | 08:05 PM
anthony05gt's Avatar
There are no MGW owners that have switched to something else. If there are any...show me one. All of the others shifters had owners that switched to MGW. It's the bomb.
Old Apr 23, 2008 | 09:00 PM
muslenutz's Avatar
Your post does not exacty tell me the differences, I can care less if anyone has switched after using a MGW. If its the bomb, explain why?
Old Apr 23, 2008 | 09:43 PM
ryan1112's Avatar
I've had a triax and I've driven cars with Pro50. They feel about the same but the Pro50 has a bit shorter throw.
Old Apr 23, 2008 | 11:12 PM
2kanchoo's Avatar
It is the most over engineered shifter made. You can tell just by looking at it. The build quality in parts, fitment, and execution is unbelievable. It is fully adjustable through the entire throw range, **** height, side to side and angle. It is the easiest shifter to powershift IE it doesn't bind when powershifting like a lot of others tend to do (IE the hurst).
From personal experience (I've had a hurst, and driven s197's with a couple different shifters) and research I've found it to be the most competent shifter available in every single area, engineering, fitment, feel, adjustability, ease of powershifting.
Old Apr 24, 2008 | 09:01 PM
OK, no problem. It is fully adjustable...that means throw length, any **** height (it slides and clamps in place), any **** position within the bezel, it has torsion mounts at both ends of the remote beam instead of a rigid mounted beam which can cause binding while shifting at high rpm's above 5500, it comes with foam insulation, rubber insulation, dynamat insulation, shift mechanism has upper and lower rubber dust boots. It has a patented noise absorbing shift handle. These are just the features that NO OTHER shifter offers. I had a Steeda Triax which the Pro50 is a copy of. It's long gone. I wouldn't own anything but the MGW and either would all of the guys I've installed them for.
Road_Runner
Sep 2, 2024 04:46 PM
Jul 8, 2016 08:53 AM
Infamous_blackbeard
Oct 8, 2015 10:45 PM
Christopher Fox Wallace
Sep 26, 2015 11:55 AM
dbrinkley2008
Sep 9, 2015 07:02 AM
