Predator Tuner
Old Oct 29, 2005 | 04:33 PM
68wanabe's Avatar
Does anyone know how the shift points are supposed to work on the Predator tuner with an automatic? Under modify parameters it has 1-2 shift point, 2-3 shift point and 3-4 shift point. When you go into these there is a scale from -20 to +20 and you move the arrow to where you want it. I am assuming if you were to move the arrow to +20 the shift point would increase by 20 MPH on whatever shift point you were working with. However I cannot see any difference at all in where the car shifts.
Old Oct 29, 2005 | 04:36 PM
tmcolegr's Avatar
After you changed the shift points, did you reflash the PCM so the changes take affect?
Old Oct 29, 2005 | 04:43 PM
68wanabe's Avatar
Yes I have reflashed the PCM.
Old Oct 29, 2005 | 04:49 PM
tmcolegr's Avatar
Your signature states you have the Steeda Predator. Which software revision is in your Predator? There were some issues with early software not applying the changes.
Old Oct 29, 2005 | 06:52 PM
68wanabe's Avatar
It is version 8 R21. Wonder if I should apply chgs to all three shift points listed. I just did the 1-2 and 2-3 points before.
Old Oct 29, 2005 | 08:33 PM
SixtySix's Avatar
Don't bother, the shift points by MPH doesn't do anything. When they first came out, it was the only option, then update R12 introduced shift points by RPM. Those work, but only apply to WOT.
Old Oct 29, 2005 | 11:25 PM
Mongoose's Avatar
For what its worth mine are currently set at 5800 rpm shift points with the rev limit set at 6800 rpm.
Old Oct 31, 2005 | 09:59 PM
don_w's Avatar
When I had a Predator, I set the WOT shift points to 6200. Seemed to work much better.
trackpack13gt
Jul 25, 2017 05:29 PM
09-gt/cs
Oct 15, 2015 10:03 AM
Bryanh24
Oct 14, 2015 08:43 AM
Antigini-GT/CS
Oct 5, 2015 09:43 AM
Grabber5.00
Sep 13, 2015 06:53 AM
