P0340 code
Old Oct 29, 2007 | 12:23 AM
06SilverBulet's Avatar
Question P0340 code
Hey Guys,
I have a issue, When ever I turn on my Stereo system and the sub hit the car surges a tiny bit. It's really weired for a while I thought it was the road or something. I would turn down the stereo and its fine but as asoon as the Sub hits it happens. I got a light so I read it, Turned out to be P0340 code. I took out the C&L and tune to be in the safe side for warranty. Driving today after a 4 days of having the code it turns off, Since I have been with my girl for the weekend and stereo low. Have guys ever seen this? It's really weired
Old Oct 29, 2007 | 05:21 AM
zoomerman46's Avatar
Well,
I had my battery die yesterday after sitting in the garage for a week and a half(first time failure). Went looking on some of the other forum's and found out a few things. Namely that the stock batteries arn't very good and may last only 2 1/2 to three years before they expire.But in your case there is a TSB 06-19-12 that states that a bad Alternator can be the source of DTC codes P0340 along with P0344.
Here is the PDF file. Hope this helps.
File Type: pdf
Old Oct 29, 2007 | 06:58 AM
dustindu4's Avatar
9 is not my lucky number.
don't clear the code
If it's under warranty still, bring it in. It's the alternator or battery or both.
Old Oct 29, 2007 | 01:06 PM
Thanks I will show them the TSB. Is there a memory of the old light since it turned off. I've had the car for almost 2 years so that might be it. Thanks Guys!
Old Oct 30, 2007 | 12:14 AM
theedge67's Avatar
You will probably have to wait for the light to reappear since you cleared it. I do not believe there is a memory of the light.
Old Nov 1, 2007 | 02:03 PM
I didnt clear it. It cleared it self. I know it should go off within 3 key Cycles if it didnt pass the paremeters. I havent had to sound up so it turned off. I haveto have it up untill Sat hopefully comes back on. Thanks!
May 3, 2026 05:42 AM
Antigini-GT/CS
Oct 5, 2015 09:43 AM
boz
Oct 1, 2015 04:47 PM
haitham
Sep 8, 2015 12:52 PM
