Owners with saleen S/C,advice
Old Aug 17, 2008 | 09:49 AM
blown red hot gt's Avatar
Im putting a saleen S/C on my 07 with a 3.5" pulley rated at about 7-8# of boost and 39# injectors.Do i need a GT500 shelby fuel pump or will my stock pump handle it.Thanks .Any input would be appreciated.
Old Aug 17, 2008 | 09:56 AM
tom281's Avatar
Your stock pump would likely handle it, you could always add a Kenne Bell Boost A Pump (BAP) for additional insurance. Whatever you do though, get it on a dyno to check output and air/fuel ratio before you go out romping on it for the first time. Who's tune are you going to run with your setup?
Old Aug 17, 2008 | 11:10 AM
tmcolegr's Avatar
I'm putting a saleen S/C on my 07 with a 3.5" pulley rated at about 7-8# of boost and 39# injectors.Do i need a GT500 shelby fuel pump or will my stock pump handle it.Thanks .Any input would be appreciated.
With a 3.4" (8.5 psi) pulley the stock fuel pump will be maxed out at 6,200 RPM and will run lean above that RPM.
Now having said that, many people are running a 3.4" pulley without upgrading the fuel pump. A FPDM wiring upgrade will allow you to run the 3.4" pulley up to 6,500+ RPM and the fuel pump duty cycle will be right at 90%.
Let your wallet be your guide.
Old Aug 17, 2008 | 03:57 PM
07GTTOM's Avatar
question down the line is are you going to run more boost? if you think you are, get a BAP or gt500 setup if you have the cash. if i was you, like mentioned, get the car on a dyno and make sure that the stock pump is doing its job. i probably would upgrade the pumps just to be safe.
Old Aug 17, 2008 | 05:07 PM
RedFire281's Avatar
Legacy Supercharged Tms Member
The KB BAP is good to 500 rwhp (KB says about 535 rwhp). I've been running mine for over 1-1/2 years with no problems.
Old Aug 19, 2008 | 03:57 PM
pittperson's Avatar
I would go with the GT500 setup for anything smaller than the 3.6. Oh, and colder spark plugs, HT0s are they way to go. Just be careful taking the stock plugs out, you dont want to break them! I just installed the 3.6" pulley with the stock plugs and had some spark blowout at WOT.
Old Aug 19, 2008 | 04:26 PM
gpp's Avatar
gpp
the pumps are far cheaper than a blown motor.
Old Aug 19, 2008 | 08:24 PM
randy_tho's Avatar
What exactly does the boost-a-pump do? Increase/stabilize the voltage to the factory to make it work harder?
I remember some turbo import guys doing a "hot wire" mod to achieve something similar.
Old Aug 19, 2008 | 08:38 PM
anthony05gt's Avatar
A Boost a pump increases the voltage to the fuel pump on demand. A larger gauge wire in also need to handle the additional amp flow.
boz
Oct 1, 2015 04:47 PM
GLOCKer
Sep 28, 2015 05:20 PM
Christopher Fox Wallace
Sep 26, 2015 11:55 AM
