Oil Separator Recommendations
Old Jan 19, 2017 | 07:11 PM
m05fastbackGT's Avatar
Originally Posted by SpectreH
By deleting the PCV, you're talking about putting those little filters on each head in place of the PCV tubes? If so, I don't think any tuning is needed if you do both heads.
If your referring to those little filters on each cam cover ? He should also disable the factory PCV system by capping off both the vacuum port to the intake manifold and throttle body prior to installing breather filters, otherwise running them with part of the PCV system still intact may cause a lean condition ..
It's also recommended to remove the integrated PCV valve from the underside of the driver's side cam cover prior to disabling the factory PCV system in favor of running breather filters..
Old Jan 20, 2017 | 10:44 AM
07 Boss's Avatar
^+1 Plus if you go with a 710 cap breather too it will all but eliminate any oil drippage that some complain about. I've never experience it but I have always run 3 open breathers on my motor.
wallace
Mar 29, 2016 10:09 AM
14Glassback
Oct 4, 2015 08:52 AM
GeoWett
Sep 30, 2015 06:40 AM
southern stang
Sep 26, 2015 04:19 PM
Jailbirdwatcher
Sep 25, 2015 06:39 AM
