Oil Change Question!
Old Nov 3, 2009 | 05:41 AM
anteyeiabazele's Avatar
5W-20 & 5w-30 what is the difference? Can I use 5W-30?
Also what is 10W-30? can i use that?
Old Nov 3, 2009 | 07:31 AM
jasongt06's Avatar
Stick with a 20 weight oil in the 4.6 3 valve engine. Either a 0w or 5w20. The first number is always the cold weight of the oil.
Old Nov 3, 2009 | 08:56 AM
NastyStang113's Avatar
What's done to the car? Supercharged? Turbocharged? N/A? I'm running the Amsoil 0w30 in my car.
Old Nov 3, 2009 | 04:25 PM
70MACH1OWNER's Avatar
Yes... 5W-20 or 5W-30 will work just fine in our cars. Stay away from 10W-30. Certain functions of our varible cam timing is controlled by the weight of the oil you run. The first number is the cold weight of the oil and the second is the amount of additives that have been added so the oil protects at a higher weight value if that makes any sense.
Old Nov 3, 2009 | 04:37 PM
tom281's Avatar
Ford Motorcraft 5/20 synthetic blend.
Old Nov 3, 2009 | 05:10 PM
ScottsVaporGT's Avatar
Old Nov 4, 2009 | 12:31 AM
Antigini-GT/CS's Avatar
Founding MOTM
Committee Member
I agree with everything in Tom's post, aside from his signature saying black gives way to blue.
Old Nov 4, 2009 | 02:44 AM
Thanks all!
Old Nov 4, 2009 | 04:01 AM
MTAS's Avatar
Thumbs up
Old Nov 13, 2009 | 06:43 AM
Ok got my oils now final question b4 i go through with the oil change...
Besides the Oil filter do I replace anything else? Or do i reuse same caps and plugs!
Old Nov 13, 2009 | 07:28 AM
theedge67's Avatar
Just replace the oil and the filter, nothing else. Reuse the plug. Just make sure when you take off the old filter the rubber ring gasket comes with the filter and is not still stuck on the engine.
Mpaps
Oct 11, 2017 08:06 PM
dblhelx
Oct 6, 2015 08:08 PM
Fernando.4ohh
Sep 10, 2015 03:35 PM
Sep 10, 2015 12:44 PM
