Oil Analysis Report
Old Jun 26, 2007 | 11:32 AM
  #41
theedge67's Avatar
I had another analysis done, this time with 5-30 Mobil 1, at around 4,500 miles. The results were quite a bit different this time. I'm not sure if the results reflect the thicker oil, or the warmer temperatures. The previous oil run was during the heart of winter with plenty of very cold starts. This run has been much warmer outside. At any rate, I am going to try 5-20 Pennzoil Platinum next and see what happens.
File Type: doc
Old Jun 26, 2007 | 11:43 AM
  #42
metroplex's Avatar
Thanks for the update Steve!
Old Jun 26, 2007 | 07:05 PM
  #43
GT John's Avatar
Here is a good read for ya. Its 123 pages long but it should help you to make up your mind on which oil is best for your car.
http://www.motor-oil-engineers.com/M...eers%20PDF.pdf
Right now I'm using Redline 5w20 for the additive package, an EAO-11 Amsoil oil filter because it filters down to 15 microns with a 98.7% efficiency and its got a FilterMag on it. (the 300lb type $39.00)
The additive package you want in your engine should be the deciding factor whether it be 0w20, 5w20, 0w30 or 5w30. Next is the best oil filter money can buy, which happens to be the EAO from Amsoil. (at this time)
Ya I'm excessive. The same guy that put a Stef's oil seperator on his engine so that the intake would be oil free.
You ask a 100 people which oil is the best and you'll get 100 different replies.
I am going to do a UOA but not with Blackstone. I will probably use Dyson.
Got to put about 4000 more miles on the Redline.
Happy reading
Old Jun 26, 2007 | 10:19 PM
  #44
theedge67's Avatar
The last oil run I did had an Amsoil EAO filter on it and I got only decent results on the analysis. This run had the Motorcraft filter on it, and my results were 2X better. This run my insolubles were down to .1%, they were .2% last run. I do believe in the EAO filters, but obviously the Motorcraft is doing an excellent job too. I think I'll stick to the motorcraft filters. They are much cheaper and good quality from what I can tell.
Old Jun 26, 2007 | 10:22 PM
  #45
06GT4RAD's Avatar
GT John can you post some info and pictures on the oil separator you mentioned. Also a materials list.
Richard
Old Jun 27, 2007 | 04:51 AM
  #46
GT John's Avatar
Good choice.........or is it. See below
http://minimopar.knizefamily.net/oil...tml#motorcraft
Sooner or later you will find the right combination, ya just gotta keep read'in and runn'in those UOA's.
Old Jun 27, 2007 | 05:06 AM
  #47
metroplex's Avatar
Quite frankly I haven't heard of many engines failing because of an extra 10 ppm wear of iron/aluminium every OCI that you might save using $6/qt oil and $10/filter.
I wouldn't waste the extra money on Amsoil engine oil and Amsoil oil filters because Motorcraft semi-synthetic 5W-20 and a FL-820-S is supposed to be good for 7500 miles according to Ford (I recall that they're now extending the OCI's). Engines aren't made of paper. I wouldn't mind spending more on ATF and gear oil since they're not changed frequently but engine oil is engine oil. As long as it meets the Ford spec and the oil filter is good (FL-820-S for $3-$3.50/filter, OEM spec, can't beat this deal), you're good to go. I use the cheapest quality 87 octane fuel I can find for the GT. I haven't heard it ping/detonate at WOT with my A/C running in the summer heat while going up a steep hill.
Old Jun 27, 2007 | 05:25 AM
  #48
GT John's Avatar
I hear ya.
Thats why its a good idea to base your selection of motor oils and filters on published facts and data.
Research into these areas is available on the Internet.
Old Jun 27, 2007 | 11:32 AM
  #49
theedge67's Avatar
Well I'm switching to 5-20 Pennzoil Platinum because I picked up a bunch of it at Advance Auto Parts BOGO sale a few months ago. It worked out to be about $2.40 a quart. Not too much more than the motorcraft oil. With the full syn I am comfortable going 7,500 miles between changes which will save me $$ and time since I drive so much. (25,000 miles/yr) I know Ford says the motorcraft oil is good for 7500, but only in certain engines and the 4.6 is not one of them.
Old Jun 27, 2007 | 03:41 PM
  #50
one_mean_marine's Avatar
Hey Steve how have the guy's up in St. Louis? I call andy and bean up and bill from time to time. As for the oil i personally use Mobil-1 5w-30 Full Synthetic and Mobil-1 Oil Filter.
Old Jun 27, 2007 | 08:00 PM
  #51
theedge67's Avatar
I never met those guys because something came up and I never made it to the dyno day that was scheduled. I really wanted to go, but oh well.
Old Dec 16, 2008 | 07:22 PM
  #52
Have you done any recent tests running 7500 miles on an oil change?
dblhelx
Oct 6, 2015 08:08 PM
14Glassback
Oct 4, 2015 08:52 AM
southern stang
Sep 26, 2015 04:19 PM
Bytor1960
Ecoboost
Sep 25, 2015 09:00 AM
Jailbirdwatcher
Sep 25, 2015 06:39 AM
