odd thing happened tonight...
Old Feb 6, 2008 | 11:14 PM
ford4v429's Avatar
legacy Tms Member
drove the car to work today(had been going thru withdrawl) and went to leave- started it up, went to take off, it went about a foot and died(stick- I didnt stall it) had to try to start it 3 times before it would finally stay running, but had ZERO throttle response- sat there chugging at 500 RPM for about 10~15 seconds, could move the pedal all you wanted, but just chugged rough at exactly 500 rpm. shut it off, started it again and perfectly normal, no fault lights or anything. it was raining a little today, guess I'd better check the passenger carpet make sure I didnt spring a leak in the SJB area(as ive read is common), but as everything was fine on the way home, kinda doubt that.
anyone recall hearing of, or having any similar issues???
Old Feb 6, 2008 | 11:39 PM
theedge67's Avatar
Strange indeed. I do remember reading somewhere on here a similar problem, but I cannot for the life of me remember what the problem was, or the solution. Maybe try searching for some things and see what you come up with.
Old Feb 6, 2008 | 11:50 PM
Stoenr's Avatar
Mine will do that if I don't wait about 20 seconds or so before jumping in and taking off.
The colder it is, the longer it seems to need to wait. Not a big deal, as I like to wait at least that long if not longer before driving away.
Old Feb 7, 2008 | 06:07 AM
Mine died on the way to work today. It acted the same way. I tried to start it a few times and then remembered the fuel shut off reset button. I pushed that twice and I was off again. I guess its from the roads going to hell in the winter months...to many pot holes
lakersfreak
Jun 13, 2022 12:29 AM
kponypower
Jun 17, 2020 07:17 AM
09-gt/cs
Oct 15, 2015 10:03 AM
MustangConvert11
Sep 30, 2015 08:01 PM
