O² sensor delete safe?
Old Jan 25, 2012 | 01:06 AM
paps's Avatar
I just installed an O/R jba x-pipe. I got check engine light on (of course no cats!) so my tuner can disable this rear sensor, i would like to know if it s safe to disable it...
rear O² sensors weren t used to correct air fuel ratio? If disabled, the ecu will not be able to provide right mix?
Old Jan 25, 2012 | 02:31 AM
irishn8's Avatar
Ya, rear O2 sensors aren't needed for a/f mixture. If ur tuner can turn them off then do it. But the front O2 sensors are needed.
Old Jan 25, 2012 | 01:52 PM
Bert's Avatar
Here is an article that explains it pretty well:
http://www.tricktuners.com/code_names.htm
In short, like Irish said, you do not need the rear O2's working to get the right A/F mixture, the rear O2's just monitor the cats to make sure they are working . . . which of course they are not in your case
Old Jan 25, 2012 | 02:11 PM
paps's Avatar
Thank you guys!
Old Jan 28, 2012 | 10:05 PM
mptant913's Avatar
http://www.bigdaddiesgarage.com/mini-cat-cel-fix.html
Just saw this
Old Jan 29, 2012 | 02:35 AM
paps's Avatar
I put a non fouler thing to avoid cel but it doesn t work. I finally removed it with my tuner.
trackpack13gt
Jul 25, 2017 05:29 PM
Cobiecane
Oct 23, 2015 08:44 AM
09-gt/cs
Oct 15, 2015 10:03 AM
