O² sensor delete safe?
I just installed an O/R jba x-pipe. I got check engine light on (of course no cats!) so my tuner can disable this rear sensor, i would like to know if it s safe to disable it...
rear O² sensors weren t used to correct air fuel ratio? If disabled, the ecu will not be able to provide right mix?
Here is an article that explains it pretty well:
http://www.tricktuners.com/code_names.htm
In short, like Irish said, you do not need the rear O2's working to get the right A/F mixture, the rear O2's just monitor the cats to make sure they are working . . . which of course they are not in your case
http://www.bigdaddiesgarage.com/mini-cat-cel-fix.html
Just saw this
Just saw this
Cobiecane
Oct 23, 2015 08:44 AM
