Nitrous Express tech help
Old Dec 16, 2006 | 10:55 PM
06GTwJUICE's Avatar
I have everything wired like the diagram says except I have NOT mounted the toggle switch to activate the system.
I ran out of daylight!
I have one question...
- The tps self learning sensor, does the switch to turn the system on have to be installed and wired for this box to show lights and signs of life? At this point it doesn't work. I've turned the key to on without starting the car and it shows no life.
Just to narrow things down a little....
- nitrous solinoid gets both wires put into one connector
- fuel solinoid gets both wires placed into the other connector
(i'm assuming the crossover on the diagram happens in the prewired loom)
- black line wiht really long wire needs the black one to goto battery power and the red one to the switch to activate the system.
- white wire gets tapped into the yellow one on the passenger side connector on the TB
CiniZter
25
Apr 28, 2016 05:41 PM
Fedupdave42169
Oct 20, 2015 10:29 PM
Omegaprime92
1994-2004 V-8
Sep 8, 2015 08:53 AM
