New Heads & Cams !!!! Pics inside of the Build...
Old May 6, 2010 | 03:25 PM
PIKE2244's Avatar
So here are some pics of the heads before they went on today along w/ the new valve covers:
The Setup:
Torq custom valve covers
Torq CNC Ported State 2 Heads:
-5 axis CNC machined
-Intake flow rate 282 CFM
-Exhaust flow rate 187 CFM
-Custom valve job
-Custom ground factory 34mm intake valves
-Custom ground factory 37.5mm exhaust valves
-Ford valve seals and locks
-steel retainers
-Torq single coil valve spring
Torq Stage 2 Cams
Cam Phaser Lockouts
Steeda Charge Motion Delete Plates
Will be more in the next few days including some videos!!!
Old May 6, 2010 | 05:43 PM
IHVOCD's Avatar
Thats freakin sweet!
Old May 6, 2010 | 05:52 PM
RedDragon777's Avatar
do these guys have a website or are they a local speed shop?
Old May 6, 2010 | 06:03 PM
70MACH1OWNER's Avatar
Looking good. Also can't wait the finish. I can't remember if you have dyno numbers from before and will you dyno after?
Old May 6, 2010 | 11:02 PM
colbymh's Avatar
Looks like crap... Just kidding. Friiikkkin sweet man. Bet u cant wait.
Old May 7, 2010 | 06:35 AM
PIKE2244's Avatar
Here is there Website: http://www.gettorq.com
They are a Local shop here in Miami but have done work for people as far away as Canada... They are good guys. And you guys would be right; I CAN'T WAIT. I get her back either today or Tomorrow. I have Dyno #'s from a Mustang Dyno at about 300rwhp but on a Dynojet I was around 320rwhp give or take... But I am pretty sure they are doing a before / after dyno.
Old May 7, 2010 | 09:41 AM
Bullitt995's Avatar
What lift are those flow numbers at?
Old May 7, 2010 | 02:42 PM
PIKE2244's Avatar
We went over this and I have it all written down somewhere but off the top of my head all I remember I put above... When I get home today I will look and let you know.
Old May 7, 2010 | 05:24 PM
PIKE2244's Avatar
The flow numbers are at .500 lift and the exhaust is rated with factory size piping. Testing with a 1 3/4” pipe yielded an additional 85+ CFM on the exhaust side....
Old May 11, 2010 | 04:42 PM
PIKE2244's Avatar
Hey sorry its taken so long... I have had a few hicups but should be done by Thursday!!!!
Old May 13, 2010 | 03:27 PM
PIKE2244's Avatar
Ok so its looking like Tomorrow!!!!
Old May 13, 2010 | 05:34 PM
SONICBOOST's Avatar
WOW..
Old May 13, 2010 | 10:18 PM
NastyStang113's Avatar
Did they tune it too? It's got more in it. Aren't you nearly full bolt ons?
Old May 14, 2010 | 08:10 PM
PIKE2244's Avatar
Yeah sorry guys few hiccups with some machining and shipping has made this process longer than it should have been.....
As for full bolt I am getting close.... I could go for a new water pump, throttle body, very likely a new FRPP Intake (Found someone who may want a tester).... and a few more suspension mods....
Old May 21, 2010 | 06:34 PM
PIKE2244's Avatar
FINALLY PICKED UP THE CAR TODAY!!!!!!!!!!!! IT IS AWESOME, SOUNDS AWESOME, AND PULLS HARD....
I will post up some videos here in the next few days... But on a
MD:
364rwhp/330rwtq
DynoJet:
416rwhp/364rwtq
After some fine tuning and small tweaks the final numbers are in...and these are SAE numbers.
NC14GT
Sep 10, 2017 04:47 PM
wallace
Mar 29, 2016 10:09 AM
Sep 30, 2015 07:02 PM
GLOCKer
Sep 28, 2015 05:20 PM
