New Fuel tank
Old Nov 24, 2005 | 06:36 PM
mikem's Avatar
I am building a second fuel system for my nitrous system.I will be using this alluminum tank that will be mounted up front with its own pump and regulator.I am making it a return style.I am going this route instead of screwing with the factory tank that has many electronics tied into it.It will activate when the Nitrous system is activated.Also upgrading the injectors.
You supercharged guys should also consider this mod.keep racing fuel in the extra tank for use when needed.
The tank is small and holds only four gallons.Perfect for my plan.
Old Nov 24, 2005 | 07:17 PM
dustindu4's Avatar
9 is not my lucky number.
nice
Old Nov 24, 2005 | 08:43 PM
Vegasjay's Avatar
Have you figured out were to mount it?? This sound's interesting...
Old Nov 24, 2005 | 10:04 PM
Sonic Brew's Avatar
Yeah where would it mount?
Old Nov 25, 2005 | 08:11 AM
Hatchman's Avatar
What they said.
Old Nov 25, 2005 | 09:40 AM
169stang's Avatar
Hey Mike, where are you going to mount that tank?
Old Nov 25, 2005 | 11:22 AM
don_w's Avatar
Not sure if this has been asked, but where will you mount it?
Old Nov 25, 2005 | 12:09 PM
dhof303's Avatar
I am betting he will relocate the battery and place it there. Anywhere else will look a little strange.
Old Nov 25, 2005 | 12:11 PM
don_w's Avatar
Maybe a dumb question, but it is safe (or even legal) to have a fuel cell in the engine compartment?
Old Nov 25, 2005 | 12:29 PM
mikem's Avatar
It will most likely be going were the battery was.yes it is legal in the engine compartment.It is about the same size as the battery.We will see.If not it will end up in the trunk.
Old Nov 25, 2005 | 01:01 PM
Vegasjay's Avatar
Where did you find that tank? I was considering dropping the stock tank all together and putting a 10-12 gal. cell in the trunk...
Edit: Another question, what type of a devise would one use to make the secondary system activate upon Nitrous use?
Old Nov 25, 2005 | 04:21 PM
mikem's Avatar
Go to Summit Racing .com. under fuel cells.
NC14GT
Feb 20, 2023 09:42 AM
unnoticedtrails
Jul 17, 2017 11:10 AM
Mrmiles1369
Sep 11, 2015 07:23 PM
