Need some help.. In a pickle
Old May 2, 2007 | 05:53 PM
Skilz4U2NV's Avatar
I was removing my throttle body today...
And I started unscrewing the 2 screws to the left of the throttle body housing itself to remove a wiring harness that is attached to it. Its held on by 2 torx screws and naturally i snapped off not one but both of them... luckily i was able to unscrew one of them by locking a a pair of pliers on the screw shaft and twisting it out.. the other one however snapped flush and there is no way to get it out...
my question is what does that wiring harness to the left control (i'm guess its the TPS sensor)and what are the chances that i can just put it back on and have it hold good with only one screw?
thanks in advance
Old May 2, 2007 | 06:02 PM
ShowGT's Avatar
You should be okay but I would want to get this fixed and not just forget about it if it was my car.
Old May 2, 2007 | 10:10 PM
hags1's Avatar
Take it to a quality machine shop....they should be able to get it out....don't try it yourself unless you have the right tools. Those screws have loctite on them and are very soft....once you start turning them out, they heat up and snap real easy....been there, done that....
oh yeah....it's another reason to leave the TB alone....
hags1
Old May 2, 2007 | 10:16 PM
Skilz4U2NV's Avatar
I took it off to paint it...Now its all painted and back on...
And yea i noticed that ford used blue loctite on those screws... if i knew that i wouldnt have taken it off...
what if i put it back on with 1 screw and epoxy the other side of it?
Old May 2, 2007 | 10:19 PM
hags1's Avatar
Boy if it was me I'd want it fixed and held on by a screw again.....
My machine shop had the broken piece out in no time.
hags1
Old May 2, 2007 | 10:23 PM
Skilz4U2NV's Avatar
yea i know what u mean...
but i'm thinkin that a 2part epoxy is just as strong as a screw ... especially holding together a part that doesnt move much...
ugh ill prolly have it drilled out...
should i get the new screws from ford or get better ones from like home depot or something?
Old May 3, 2007 | 04:49 AM
Louie's Avatar
+1 on taking it to a good machine shop and have it drilled out.
Old May 3, 2007 | 05:09 AM
goldenpony's Avatar
Broken Screw
Yea, the epoxy will hold it, but it won't clamp it, so you could get an air leak. Get it fixed right.
ohsix750
Sep 13, 2014 10:39 PM
Gamerfanatic
'10-14 Interior and Audio
Jan 13, 2014 01:50 PM
MBonetti87
Jan 3, 2014 03:41 PM
saleenstang
1994-2004 V-6
Nov 28, 2004 07:25 PM
Roy
Sep 17, 2004 03:31 PM
