Need help with rear shock removal
Old Aug 31, 2008 | 09:52 AM
garbledwords's Avatar
Help - I can't get the top nut off of the rear shock! I'm in the middle of replacing the shocks and springs with some Steeda stuff, and I can't get the rear shocks off. I've clamp'ed on the very top of the shock and backed off the tighting nut almost all of the way. But the very last fraction of inch is not going. I've run out of room at the top to hold on to.
Any tips or suggestions?
Old Aug 31, 2008 | 10:36 AM
Ahh.. success. I managed to get one bent sideways (not on purpose) which froze the spline and I was able to undo that nut. For the other, I got my vise grips between the lower grommet and the shock itself (in the wheel well). That was sufficient to hold on the spline and I got the second one off. I was really getting concerned that I wasn't going to get them off and that I would need a shop to do it.
Old Sep 1, 2008 | 09:43 PM
soitsav6's Avatar
sounds like you struggled through, on the next ones you might change there is typically a hex top to the shock that you can put a wrench on to hold the shaft, lessons learned.
Old Sep 2, 2008 | 09:40 AM
Thanks for the reply. That wasn't the problem. I couldn't keep a grip on the inner top at the very last unscrewing the nut. There wasn't enough room to keep a grip and backoff the nut. Don't know why.
Mpaps
Oct 11, 2017 08:06 PM
Fords4Ever
Oct 30, 2015 09:07 PM
fredovega
Which is Better
Sep 3, 2015 07:20 PM
