My alignment report
Old May 30, 2005 | 03:38 PM
Redfire 05Gt's Avatar
My alignment report
Note: car has been lowered 1-1/8"
Camber
Min Nominal Max Actual
-1.25 -0.75 -.25 -1.80
Caster
6.60 7.20 7.60 7.70
Toe
-.10 0.10 0.30 0.03
My dealer does not recommend camber adjustment procedure 204-000-1 as it is highly labor intensive and weakens the structure of the component.
So, which would you pick: Ground Control's Caster/Camber plates at ~$375 CDN or Steeda's Billet camber plates at ~$270 CDN and not worry about the caster adjustment? I imagine the labor for the caster/camber plates is likely double that for the camber plates.
[attachmentid=22776][attachmentid=22775]
Old May 30, 2005 | 06:42 PM
bullittman's Avatar
Originally posted by Redfire 05Gt@May 30, 2005, 9:41 PM
My alignment report
Camber
Caster
6.60 7.20 7.60 7.70
Toe
-.10 0.10 0.30 0.03
So, which would you pick: Ground Control's Caster/Camber platesat ~$375 CDN or Steeda's Billet camber plates at ~$270 CDN and not worry about the caster adjustment? I imagine the labor for the caster/camber plates is likely double that for the camber plates.
You're over the limit.......Over time you would probably see more wear, other than that I had the local garage remove my struts, I then opened up the area for the camber plates (Steeda). The garage then installed my struts and aligned the car. They charged me $75. I had about an hour of work myself on them. Your mechanic is probably right about weakening the strut,if all you do is slot them. The Steeda plates,although expensive are first rate and supply the needed support on the slotted holes.
Old May 30, 2005 | 06:53 PM
sodaman's Avatar
I would use the plates, and get those numbers in order. You are off on every item it seems, you will like it better in spec than out. If you dont you may pay a lot more down the line, since tires arent cheap etc.
Old May 30, 2005 | 09:46 PM
Originally posted by bullittman+May 30, 2005, 4:45 PM--><div class='quotetop'>QUOTE(bullittman @ May 30, 2005, 4:45 PM)</div><div class='quotemain'>You're over the limit.......Over time you would probably see more wear, other than that [/b]
It pulls nice and quick into the corners...
So is 1.5 hours about right for a shop to remove the struts, elongate the holes and reinstall the strut with the Steeda plates?
Thanks. Toe-in is within spec.
<!--QuoteBegin-Blazing Saddles
@May 30, 2005, 5:50 PM
FYI: Oval holes are actually stronger than round ones. At work I make a part for the CFM56 jet engine. This part rotates at 40,000 RPM's and has 48 oval bolt holes in it.
I wouldn't hesitate for a minute on useing the camber adjustment procedure 204-000-1. There are probably millions of cars on the road today that use a cam bolt to adjust the camber. As for labor intensive, sorry I just had to laugh at that one. It would probably take all but 15 minutes each side. I'd find another place to get your frontend done.
[/quote]
From what I've read about 204-000-1 I think it gives another +/- .75 of adjustment? If so, that would get me down to -1.05 which I think would be acceptable. Otherwise at shop #1 I'm looking at 270 + 137 + 47 = 454 to have the Steeda plates installed and the alignment done again. (That's $365 USD)
Old May 30, 2005 | 10:23 PM
Cleveland's Avatar
My alignment report is...
Camber: -1.5 / -1.5
Caster: +5.5 / +5.5
Toe: .05
I was told that if I continue to drive aggressively my tire wear will be normal.
-Dan
Old May 31, 2005 | 08:30 AM
adrenalin's Avatar
My camber was way off and I had the 204-000-1 procedure done on my car. I am just within the tolerance levels. Front tires, especially drivers side are still noticably at an angle, however, uneven tirewear should be minimal. I don't see how "notching" the strut will make it weaker.
Old Jun 3, 2005 | 01:33 PM
rony1976's Avatar
who has caster/camber plates available? Just camber plates adjusters from Steeda?
Old Jun 3, 2005 | 01:39 PM
The link is in my post at the beginning of this thread to Ground Control's Caster/Camber plates...
Old Jun 3, 2005 | 01:42 PM
killo-11's Avatar
Originally posted by Redfire 05Gt@May 30, 2005, 3:41 PM
My alignment report
Camber
Caster
6.60 7.20 7.60 7.70
Toe
-.10 0.10 0.30 0.03
This is BS having to mod and spends so much money to make a new car ride correctly. Ford should do this mod at there expense.
Old Jun 3, 2005 | 02:10 PM
For a $30K car, it rode fine the way it was. I was the one who chose to lower it to change it's appearance.
Old Jun 3, 2005 | 03:59 PM
killo-11's Avatar
You should have said that in you post.
Old Jun 3, 2005 | 04:14 PM
RRRoamer's Avatar
Am I the only one that automatically thinks "lowered" whenever I see the work "alignment" in reference to an 05 GT???
Old Jun 3, 2005 | 05:48 PM
Ahh, Michael (killo-11), you're right, I guess iI should have stated that. Just that with all the threads that have been talking about camber have been in relation to lowering springs, I guess I overlooked that detail.
My apologies...
So, everybody, given two choices 1) Steeda Billet Camber Adjusters or 2) Ground Control Caster/Camber Plates, which one would you go with?
Ground Control Camber / Caster Plates: Correct camber adjustment at the top of the strut. Caster adjustment, aircraft bearings, engraved with calibrated degrees. Every component is anodized or plated, including fasteners. Adds extra travel to avoid excessive bottoming out, this is a very well engineered product.
Camber and caster are adjustable by sliding the mounts, without removing any components from the car. The priority of this design is to allow repeatable alignment changes which the 2005 Mustang needs.
The Ground Control camber plates feature a bearing and a bushing, which allows for articulation of the shock shaft. The steering bearing is very under stressed, as the Ground Control design does NOT articulate the steering bearing
Now, if Maximum Motorsports only had theirs available for the '05...a quick phone call and...not this month, most likely July!
OneCoolGT
Dec 10, 2015 07:55 PM
Sep 16, 2015 06:44 PM
DrisStang
Sep 14, 2015 06:20 PM
robjh22
Sep 8, 2015 12:31 PM
Sep 1, 2015 01:19 PM
