Mustang GT engine spec database
Bore X Stroke (in/mm): 3.552 X 3.5433 (90.2 X 90)
Bearing Size: .62"?
Intake Valve Diameter: 1.33"
Exhaust Valve Diameter: 1.477"
Intake Port CC's: ?
Exhaust Port CC's: ?
Intake Port Length: ?
Exhaust Port Length: ?
Chamber CC's: ?
Split Intake Ports: ?
Intake Manifold Volume and Length: ?
Intake Manifold Runner Flow Coefficent: ?
Exhaust Header & Collector Volume: ?
Exhaust Header Flow Coefficient: ?
Muffler CFM rating: ?
Cam Centerline: ?
Cam Duration: ?
Cam Lift: .437 (Intake) / .433 (Exhaust)
Rocker Arm Ratio: ?
Valvetrain Specs: ?
Compression Ratio: 9.8:1
Head flow table (according to MM&FF)
Lift Intake CFM Exhaust CFM
.2......146...............107
.25....179...............118
.3......208...............130
.35....222...............138
.4......229...............147
.45....233...............154
.5......235...............159
.55....237...............163
Feel free to add anything
Bearing Size: .62"?
Intake Port CC's: ?
Chamber CC's: ?
Cam Centerline: ?
Cam Duration: ?
Rocker Arm Ratio: ?
Valvetrain Specs: ?
I wish I could add something. This is beyond my expertise.
But I hope you get some response since I think it is this sort of information (car specifications, pictures of the guts of the car, problems, etc.) that makes the site most valuable.
See the Specs pages.
http://www.squadengine.com/~bill/200...tang_specs.pdf , on page 5 of 37 (page 3 according to the document after 2 non-numbered index/title pages)
You will find some of your missing items, and lots more good stuff.
B) Way keeeeewwwwllll
