Which makes more sense?
Old Mar 26, 2008 | 10:56 PM
Jon_Purdy's Avatar
Which makes more sense? Greasable bushings or maintainance free bushings? I ask because I have to go under the car to replace a cracking UCA bushing on Saturday. The current UCA has a zerk fitting for applying grease. After a while, I wondered if switching to a maintainance free UCA from either MRT or CHE would be a better option for me. Is there a difference in performance between the greasable and maintainance free bushings? I like the idea of not having to re-grease the bushing every so often but not if it means lower performance.
Jon
Old Mar 26, 2008 | 11:41 PM
MooStang05gt's Avatar
I can't say much about the maitenance free bushings. My BMR adjustable UCA has the poly bushing with the grease fitting. A good quality chassis has made for a smooth and quite operation.
You will probably be OK with the maintenance free bushing, I just haven't ever used one. You defenately don't want a spherical bearing because of the noise they make.
Bobby M.
Old Mar 26, 2008 | 11:47 PM
Jon_Purdy's Avatar
Thanks for the quick reply Bobby. I too have the BMR UCA (adjustable). The bushing inside the thing is cracking, BMR sent out replacements but they might be the wrong ones, will confirm tomorrow. I have an appointment with the guys at MRT on Saturday. If these are indeed the wrong bushings I might have to go with their maintainance free upper, leaving the BMR mount in the car for added rigidity.
Jon
Antigini-GT/CS
Oct 5, 2015 09:43 AM
PonyMuscletang13
Sep 26, 2015 02:33 PM
MustangGTCS13
Sep 17, 2015 07:38 AM
robjh22
Sep 8, 2015 12:31 PM
