Maintenance free LCA's and panhard bar
OK,
I'm ready to buy LCA's and a panhard bar. I'm basically lazy and I want a maintenance free solution.
What do I want to buy?
well there's a lot of very expensive LCA's out there, but i went with these:
http://www.hotpart.com/index.php?p=show&id=151
and they work great!!!! lca's are lca's, no point in spending a bunch of cash on them when they are all pretty much the same.....
pretty much maintenance free.. mine have been in for over 6 months now and no problems yet, no unexpected squeeks or anything either
I'm running the J&M rear lower arms also, they are easy to install and don't squeak or anything. I greased them very well with the supplied grease and they haven't ever made any funny noises. They made a big difference in traction too, no wheel hop.
Also running the J&M LCA's here. Definitely maintenance free. Packing the bushings takes a few minutes, but they're worth it. I prefer them to the BMRs I had before by quite a bit.
lightweight=good, I believe unless you are going to be throwing down some serious numbers the aluminum would be just fine, if soething stronger is needed maybe look for some moly steel
You can get Spohn control arms and panhard bars in chrome moly. I've used their lower control arms, they were a little noisy but well made.
http://www.spohn.net/shop/2005-2008-.../Panhard-Bars/
How about this (about 3/4 down the page)
http://mrt-direct.com/v3/Chassis%202...is%202005+.php
looks like a good one, havent heard anything good or bad either way, however everything I have heard about other MRT has been 1st class, I have had the BMR's which I changed out for the J&M, I liked both of them but more partial to the J&M as after I changed them out my added road noise from the BMRs was cut down to almost nothing, I dont think you will go wrong with any of the options mentioned here, one thing I will be doing to my aluminum panhard bar from J&M is polishing it, it turns out very nice and shiney!
Picked up adjustable Steeda LCAs w/ urethane bushings on-sale @ MossMustang
http://www.mossmustang.com/Shop/View...eIndexID=48513
![](http://www.mossmustang.com/Graphics/Products/Large/055-128_1.jpg)
Look nice, haven't installed yet (still waiting to get the car!)
$100+ off original price, though. Makes it easier to adjust pinion if you ever get a driveshaft.
