M/T Drag radials
Are those wheels available with the '05 off-set?
[/quote]
I'm not absolutely sure about the offset. It just shows them as 2005. I have an email into them to find out. I'll relay any info I get.
[/quote]
Originally posted by b_btrick@February 13, 2005, 12:39 PM
Kind of an interesting read, and if you scroll to the bottom (an actually throughout the article) there are quite a few links to companies manufacturing rims (wheels) that you might like.
http://www.roadsters.com/wheels/
http://forums.bradbarnett.net/index.php?showtopic=15394
Oh, wait, you started that thread.
![Biggrinjester](https://themustangsource.com/forums/images/smilies/biggrinjester.gif)
[/quote]
Thanks! If they are available or will be soon, I would guess there will be quite a lot of interest in them. For one, Me!
Will 16" wheels fit on the 05 or will that be cutting it close?
As far as running anything smaller than a 17"dia wheel, everyone I've heard from has said a smaller diameter wheel will not clear the GT brake calipers.
Well all I know is there is a big difference between a drag radial and "Street Slicks" like ET Streets.
If you are buying them strictly for the track get the Street Slicks. I put mine on at home and drive them to the track, they kinda stink bigtime going around corners, but they rock going in a straight line!
I have a couple of friends with '03-'04 Cobra's running 16" wheels with the M/T drag radials and they hook pretty well. A 16" tire will give you more sidewall flex. A GT can get by with 15's on the back.
