Lowering spring (help)
Old Dec 14, 2010 | 11:27 AM
Luii 06stang's Avatar
I have some aibach lowering springs on my gt & I have a tire wearing problem....
Does anybody know what else I need to get my tires straight??
Old Dec 14, 2010 | 12:39 PM
d_bone33's Avatar
here is the deal man. I have the same kit and the same problem With the eibach kit it puts your car in some camber that you can't correct. There is a kit you can buy its around 50$ i believe its a caster/camber bolts or something like that. I forget, but basically you need to buy the caster/camber bolts and put them on and have it realigned...hope that helps
Old Dec 14, 2010 | 03:00 PM
Thanks dude, some one had told me about it, but wasn't sure about it
Old Dec 14, 2010 | 03:24 PM
Did u use that in Ur pony?
& did it work?
Old Dec 14, 2010 | 05:49 PM
jsnyng's Avatar
Here you go --> http://www.stranoparts.com/partdetai...205&ModelID=35
Old Dec 14, 2010 | 06:50 PM
bingo /\ /\ and you can ask your alignment guy to stand your tires up a little straighter than stock. Because I think at stock settings the tires still wear on the insides. Make sure you tell them you have camber bolts in there that is unless your having them put them in
Old Dec 14, 2010 | 08:31 PM
Originally Posted by jsnyng
Thanks I'll look forward to those
Old Dec 14, 2010 | 09:08 PM
ARBO's Avatar
This info is right on, I put the bolts on my 06 while installing springs. Then took it in for alinement. NAPA has them too. But I don't remember the part #. It's on the site here somewhere. Not to take away a sale from Sam, but if you're in a time crunch, NAPA could be quicker if you can find the PN.
Old Dec 14, 2010 | 10:13 PM
Oh thanks bro
Hey u think I could find it in Ur page?
Old Dec 14, 2010 | 10:15 PM
5pointoh's Avatar
After you lower your stang.....you will need a minimum of two things to prevent the tires from wearing excessively.
1. wheel alignment
2. camber bolts (I believe CJ Pony parts has got a good price on these)
Old Dec 15, 2010 | 10:40 AM
ARBO's Avatar
Originally Posted by Luii 06stang
Oh thanks bro
I don't know. Do I have a page? I'll try and search, but I'll warn you , I don't have much luck with searching for some reason. But I'll try now.
Old Dec 15, 2010 | 11:02 AM
ARBO's Avatar
I found it. This is what I used on my 06, while installing springs (Eibach). Then I went and had it alligned. NAPA part #NCP 264-3642 If I remember right, the NAPA people (at that time) say it's a camber bolt for something else. But three of us used it and it gave it enough to do the job. No tire wear issues.
Old Dec 15, 2010 | 04:31 PM
1. wheel alignment
Thanks a lot dude really appreciated the help
Old Dec 15, 2010 | 04:32 PM
Thanks for the help
Now time to install these pars in the pony
Autotooner
Nov 24, 2017 12:42 PM
GeoWett
Sep 30, 2015 06:40 AM
Evil_Capri
Sep 25, 2015 12:56 PM
