Lowering the front of the Mustang
Old Nov 28, 2004 | 02:46 PM
upstate's Avatar
Since I don't know much about drop kits....Can you put the 1" drop springs (steeda) in the front ONLY, to give it a more raked look. Would this cause problems? Kind of like what we used to do to the cars in the 60-70's.
Old Nov 28, 2004 | 03:08 PM
imook16's Avatar
The cars balance would be totally off. You'd wind up "diving" everywhere when you apply the brakes. Not so good if you want to do alot of spirited driving around corners and such. You could tail out real easy with that set-up.
Old muscle cars were raked like that to prevent the front from lifting too much while dragging, also in order to clear a larger rear tire.
If dragging is your thing, then I'd say go for it. If it isn't, then I'd say don't sacrifice the '05 improved handling.
Old Nov 28, 2004 | 03:37 PM
RaGsHoCkEy88's Avatar
i dont think im gonna touch the suspension or anything that has to do with it for a while
Old Nov 29, 2004 | 08:49 PM
adrenalin's Avatar
You can't just use springs. Check out all of Steeda's parts and you will see what I mean. Definately you have to lower both front and both. I agree imook16, you will be all over the place when bracking. Also kiss your alignment goodbye
whysoserious
05-09 Interior and Audio Mods
Oct 27, 2023 06:42 PM
Ecostang
Nov 3, 2022 08:50 PM
RocStar69
Aug 21, 2015 07:33 AM
