Lower idle revs
Old Dec 22, 2004 | 02:35 PM
38special's Avatar
My car used to idle at 1300 RPM until warm , then it would settle around 900 RPM.
Without the HC trap it now idles at 600 RPM. Any one else experience the same
drop?
The eco cops are causing us to waste fuel, AGAIN!
Old Dec 22, 2004 | 02:41 PM
Kluski's Avatar
I'll check mine on the way home. I can't remember where it idled before. I don't understand the benefit, if there is a better gas mileage without it. I guess they think there is a trade-off somewhere.
Waste more fuels, but have cleaner air. Heck, there is probably more air pollution by refining the additional gas spent to use the filter.
I don't know, higher MPG and HP, I will vote for that.
Old Dec 22, 2004 | 06:43 PM
wild stray's Avatar
Mine idled (at temp) at 900 before & now idles at 750
Old Dec 23, 2004 | 07:43 AM
Kluski's Avatar
Yup, mine was about 750 also.
Old Dec 23, 2004 | 08:21 AM
BillP's Avatar
Mine's still at 900, but I also had the SCT 91 and 87 flashes tuned to the car without the HC trap, my dyno shop may have corrected to 900.
Old Dec 23, 2004 | 09:57 AM
Kluski's Avatar
Is it bad to have it lower? Or less beneficial in some way?
Old Dec 23, 2004 | 11:43 AM
fleasome's Avatar
Culled From Here
Hydrocarbon Traps
Hydrocarbons produce 70 - 90% of total tailpipe emissions during cold start.[20] Recalling that 80% of all emissions occur during cold start, it is thus very important to decrease hydrocarbons. HC traps consist of a substrate material covered with zeolite. During cold starts the zeolite has an affinity for HC and will absorb them until the trap reaches approximately 302EF near 20 seconds after a cold start. At this temperature, the HC are released into the catalytic convertor for oxidation. This suggests that the coupling of an HC trap with an EHC will produce very beneficial results. Such a system was constructed for the 3.1 liter V6 tested, however time was prohibitive in determining the effectiveness of all components. The entire system is displayed in Figure 19.
Old Dec 23, 2004 | 02:43 PM
BillP's Avatar
Fleasome-
That's a HC trap using the same technology, but used on the exhaust. The one we are removing is on the intake to capture vapors due to injectors having blasted a bit of fuel into the intake during engine shutdown.
Old Dec 24, 2004 | 06:02 AM
38special's Avatar
It must of been because of the really cold weather around here lately, but it now idles at around 750 too. So you get it to idle less 150 rpms. This means all kind of things besides better mpg. One thing that comes to mind would be wear and tear on the engine itself would be less.
Old Dec 25, 2004 | 01:05 AM
TURBO 05's Avatar
it could also mean your alternator and water punp are not spinning at optimal speeds
but i dont know!!!
Old Jan 2, 2005 | 08:56 PM
38special's Avatar
Even though it revs lower. Overall mpg only went up from 19.0 combined to 19.2 combined. I was hoping for more but I guess it will have to wait until the CAI kit.
Old Jan 2, 2005 | 10:27 PM
holderca1's Avatar
I still have the trap in there and I idle at 750, it will idle at about a 1000 for a minute after startup then it will stay at 750.
Antigini-GT/CS
Oct 5, 2015 09:43 AM
Evil_Capri
Sep 25, 2015 12:56 PM
samjluck
Sep 17, 2015 10:24 PM
