Long tube headers
Originally posted by killo-11@May 6, 2005, 2:07 PM
Who has the best price and whats the best tube size?
[attachmentid=20354]
1 5/8" headers only. Tig welded 304 s/s headers with 3/8" thick flanges and smooth flow collectors. 3" od slip joint collector $699
1 5/8" headers. Includes (2) 3" off road pipes, 3" lead pipes to connect to factory exhaust system. Tig welded 304 s/s headers with 3/8" thick flanges and smooth flow collectors. Includes (2) 24" long front o2 extensions, (2) 16" long rear O2 extensions, (2) adapters stubs to fit factory exhaust system, (2) adapter stubs to fit 3" Stainless Works exhaust system, (8) 3" single band clamps $899
1 5/8" headers. Includes (2) 3" high flow converters, 3" lead pipes to connect to factory exhaust system. Tig welded 304 s/s headers with 3/8" thick flanges and smooth flow collectors. Includes (2) 24" long front o2 extensions, (2) 16" long rear O2 extensions, (2) adapters stubs to fit factory exhaust system, (2) adapter stubs for 3" Stainless Works exhaust system, (8) 3" single band clamps $1299
1 3/4" headers only. Tig welded 304 s/s headers with 3/8" thick flanges and smooth flow collectors. 3" od slip joint collector $799
1 3/4" headers. Includes (2) 3" off road pipes, 3" lead pipes to connect to factory exhaust system. Tig welded 304 s/s headers with 3/8" thick flanges and smooth flow collectors. Includes (2) 24" long front o2 extensions, (2) 16" long rear O2 extensions, (2) adapters stubs to fit factory exhaust system, (2) adapter stubs to fit Stainless Works 3" exhaust system, (8) 3" single band clamps. For high HP/Blown/NOS applications $999
1 3/4" headers. Includes (2) 3" high flow converters, 3" lead pipes to connect to factory exhaust system. Tig welded 304 s/s headers with 3/8" thick flanges and smooth flow collectors. Includes (2) 24" long front o2 extensions, (2) 16" long rear O2 extensions, (2) adapters stubs to fit factory exhaust system, (2) adapter stubs to fit Stainless Works 3" exhaust system, (8) 3" single band clamps. For High HP/Blown/NOS applications $1399
Contact Al or Scott at Stainless Works
1-800-878-3635
-Daniel
Agreed! That's what I have and it is great! I didn't think I'd like the sound of it, but I love it. It's suttle at idle, but when you stomp it, it's loud. I went to the track tonight and I felt like I just got the car all over again last November. People were all over it.
Originally posted by acadian@May 7, 2005, 10:54 AM
If you want another option, MAC has 1-3/4" longtube headers and you can get them for $430 at partshopper.
I thought stainless steel didn't rust
Keeps the headers cooler. If I thought about it, I would have had mine coated. Wish I had! Nothing is noticeable, but I know the extra heat is helping anything.
Are the MAC LTs Stainless, doesn't say it on parts shopper?
I found this description which leads me to believe that they're not:
"MAC 1.75'' Long Tube Race Headers, Ceramac Coated for GT
3 year warranty includes welds, material, burn off and rust through. Limited to replacement or repair by MAC. Warranty does not include scrape & dent damage, surface rust, discoloration from extreme heat, improper installation or neglect. "
The description for the Pro Chamber specifically says "100% Stainless Steel"...
JBA long tubes are the best mod I've done so far. Thier fit, finish, and overall quality are the finest avalable...They produced a solid 20 RWHP gain/ 22 RWTQ. I don't know much about the other brand's, just thought I would share my JBA experiance.
Coated headers allow the heat to escape faster out of the exhaust. On motorcycles (and some headers) if you wrap the headers the hot air flows out of the exhaust faster. Keeps the engine area cooler and gives a little bit of a performance increase. If I get headers I will definately be getting ceramic ones.
