LCA/UCA install how-to?
Old Oct 30, 2007 | 05:45 PM
jwgroovin's Avatar
I could swear I found an install walkthrough for both LCAs and the UCA on this forum a bit back, but can't seem to find one (even our trusty Taco Bill doesn't have one!). Searches don't seem to be turning it up. Anyone???
John
Old Oct 30, 2007 | 06:13 PM
LEO_06GT's Avatar
John
If you can wait a couple weeks I'll be installing my LCA's and LCA relo brackets at Bill's and he'll more than likely make a write-up using the pics he takes during my install. As for the UCA your on your own.
Old Oct 30, 2007 | 06:20 PM
jwgroovin's Avatar
I want to get it done prior to this weekend so I can go compete at Englishtown, NJ and try to get my ETs down a few more tenths. MM&FF will be there--might make a future issue!
John
Old Oct 30, 2007 | 07:00 PM
Gleamin05's Avatar
Smile
John
These should help.
File Type: doc
File Type: pdf
Old Oct 30, 2007 | 07:33 PM
Import-Slaya's Avatar
Installation is pretty straight forward and I've done it twice now--15 minute job a side. Jack up the rear and put jack stands under the rear axle tubes. Be sure that when you lower the rear onto the jack stands that the axle tubes land squarely on the jack stand cradles. The more you are off, the more the axle will shift when the bolts come out (*see below).
Only do one arm at a time. REPEAT--only do one arm at a time.
Pop the emergency brake cable off each brake caliper. I used a screwdriver to pop the cable end off. Remove both bolts/nuts. Take the stocker out. Reverse to install and torque to spec.
Note that there is an offset in the width of the back end bushing of the stock LCA. Be sure that the offset in the new arm is oriented towards the correct side of the car.
Zip tie the emergency brake cable to the LCA. Repeat for the other side.
*Have a ratchet strap handy. It is hard to avoid having the axle shift a very slight amount, which misaligns the holes where the back of the LCA's attach to the axle. Hook up the ratchet strap and it takes a second to cintch it back into place.
Old Oct 31, 2007 | 04:51 AM
jwgroovin's Avatar
Thanks guys, it should be a breeze given the instructions. I'm home today so I should be able to get the LCAs, UCA, shocks and swaybar relocation brackets done in one day then...
John
Old Oct 31, 2007 | 06:34 AM
good luck have fun
Old Oct 31, 2007 | 11:30 AM
RadBOSS's Avatar
Goes w/o saying, but don't forget to torque the UCA and bracket according to spec's as well or soon you will be hearing noises.
Old Oct 31, 2007 | 11:55 AM
jwgroovin's Avatar
Lowers are in, QA1 adjustable shocks going in after I wolf down lunch, then underdrive pullies. Tomorrow, the car goes on a lift to make the upper control arm install less of a strain on my shoulder, and set the pinion angle. The the track Sunday to dial the sucker in...
John
Old Oct 31, 2007 | 07:36 PM
RadBOSS's Avatar
Nice tribute car.
John
Old Nov 1, 2007 | 12:23 PM
jwgroovin's Avatar
Nice tribute car.
One of these days I'll snap a pic off while it's resting next to the real thing. Seen several '69s at local car shows, but none of them red so far...
John
Old Nov 2, 2007 | 09:36 AM
scramblr's Avatar
Here's an LCA write up.
http://www.2005stang.com/gallery/alb...%20install.doc
14Glassback
Oct 4, 2015 08:52 AM
Sep 10, 2015 12:44 PM
jim010
Sep 7, 2015 02:40 PM
SMOKE46
Sep 6, 2015 09:40 PM
