larger heat exchanger for street
Old Nov 1, 2010 | 07:52 PM
gpp's Avatar
gpp
i have a 06 gt with a saleen sc,auto trans,9lbs boost,460 rwh.do i need to run a larger heat exchanger for just street use.if i go to 12 to 13 psi would it be needed?its not a daily driver.
Old Nov 1, 2010 | 08:39 PM
PIKE2244's Avatar
I am going to be running somewhere around 14-16psi and would like to know the same question???
Old Nov 1, 2010 | 09:46 PM
Doogie's Avatar
Where do your IAT's run??
Old Nov 2, 2010 | 07:22 AM
PIKE2244's Avatar
Well to be honest my motor is in the process of being built so not sure this is more of a preemptive question???
Old Nov 2, 2010 | 04:49 PM
gpp's Avatar
gpp
and i can tell you all you want to know about a carberator but forget fuel injection.
Old Nov 4, 2010 | 09:12 AM
908ssp's Avatar
Keeping the intake air temperature down is a cost effective way of preventing pre-ignition and motor destruction.
Old Nov 4, 2010 | 10:41 AM
PIKE2244's Avatar
Yeah I decided that is def. needed as you are right great way to prevent a catastrophe!!!
Old Nov 4, 2010 | 11:04 AM
Imatk's Avatar
A larger heat exchanger will help keep the temp down and by doing that will prevent the computer from pulling timing due to heat soak.
It's unlikely that you'll prevent detonation with a larger HE. If the tune is on the ragged edge and is too aggressive then you will, but I wouldn't recommend running a tune that aggressive in the first place.
I had the Saleen Extreme HE and it was very good.
Old Nov 4, 2010 | 11:15 AM
PIKE2244's Avatar
No I am going to be running my setup well w/in the limits I just figure a larger HE is just that much more insurance!!!
Old Nov 4, 2010 | 07:37 PM
Doogie's Avatar
My question was to the OP
I just upgraded mine to an Afco dual pass heat exchanger, but will really not know the impact until next summer when things get hot around here again. My IAT's never went over 130, even when sitting in traffic when it was 90 outside. The key benefit of keeping your IATs down is reducing the chance of timing getting pulled in due to excessive heat... which obviously kills HP.
Old Nov 9, 2010 | 01:57 AM
CandyRedGT's Avatar
Killing HP is exactly why i'm installing a dual fan large exchanger.
May 3, 2026 05:42 AM
boz
Oct 1, 2015 04:47 PM
Evil_Capri
Sep 25, 2015 12:56 PM
