KB BAP on max, wasting a lot of fuel?
Old Sep 1, 2008 | 09:04 PM
08VistablueGT's Avatar
Well KB recomended to just set the control module on max for my nitrous setup. However, I feel like my fuel economy has been going down. Significantly, not really. However KB told me that the BAP doesn't even increase fuel flow unless your maxing out your stock fuel pump. If this is correct, why would the fuel consumption go up, even under regular driving?
Thanks,
Brandon
Old Sep 2, 2008 | 06:34 AM
dustindu4's Avatar
9 is not my lucky number.
I think it's all in your head
Old Sep 2, 2008 | 11:51 AM
I'm just telling you what a KB rep said on another forum.
Old Sep 2, 2008 | 01:52 PM
jamesdem1123's Avatar
short answer, no. there should be no increase in fuel consumption.
with the returnless fuel system it uses the fuel pump driver module and fuel pressure sensor to continously turn on and off the fuel pump (pulse width modulation) to get the required pressure.
the kenne bell boost a pump increases the voltage to the pump (to about 20volts). in comparison its like have a ceiling fan on medium as the stock setup and for the boost a pump, turning the fan on and off to maintain the same rpms as on medium.
i think you can datalog the fuel pump duty cycle with the SCT. record WOT with BAP on and with BAP off.
Old Sep 2, 2008 | 01:54 PM
sorry for being brief, its 11 and i have to get up at 4 tomorow to get ready for mission
Old Sep 2, 2008 | 02:50 PM
tom281's Avatar
The BAP won't push more fuel unless you're going WOT.
Old Sep 2, 2008 | 03:24 PM
70MACH1OWNER's Avatar
I wanted to say the same thing earlier today but I have to admit it has been years since I had a BAP from Kennebell. (On a 1996 Cobra) But I thought there was a switch and it turned the BAP on only when you were are WOT. Hence there is no reason for you to be using more fuel UNLESS you are spending alot more time at WOT!
Old Sep 2, 2008 | 09:16 PM
SSilver0702's Avatar
Are you running two different tunes for the car: one for nitrous and one for normal, everyday driving? I'm not sure if this has anything to do with the increased fuel consumption, but I remember reading somewhere that a nitrous tune doesn't work to well for everyday driving . Could this have anything to do with the problem?
Old Sep 2, 2008 | 09:19 PM
These are all very good points. Thus far, I'm not impressed with KB's customer service, not only at a knowledge standpoint, but also with customer relations.
My tune is the same as my n/a tune. Since the Zex nitrous management unit does all the a/f mixtures, all the Brenspeed tune does is retard the timing a bit.
Old Sep 3, 2008 | 09:46 AM
boost a pump is probably on all the time, unless you installed a vacuum switch which almost no one does. look up tacobills install. theres two wires that are just connected with a wire cap. retarded timing can cause a slight decrease in efficiency.
JonathonK
Which is Better
Nov 17, 2017 12:02 PM
Sep 16, 2015 06:44 PM
DrisStang
Sep 14, 2015 06:20 PM
