Just Made an Appointment for My Gear Install
3rd Times A Charm
Saturday 2/4/2006 10:00 AM
Altered Speed
So far for performance, I have:
C&L Intake/SCT Xcal2 - Hurst Shifter - Pypes O/R H Pipe - Flowmaster American Thunders
I have been debating over suspension mods, gears, or wheels for a while now. I have decided on BMR Suspension (check out there deal on springs), 4.10 FRPP gears, and 18x9/18x10 Deep Dish Bullitts.
Now what order do I get them. Should I make sure I get the springs first before I get the wheels? Should I make sure I have LCAs before I get gears?
My S197 is a daily driver with the occasional drag race. I don't know jack when it comes to suspension. I could just order everything BMR makes, but what do I really need?
So far I've decided on the more dramtic 2" drop springs, the adjustable panhard rod, and the tubular LCAs. Will I need anything else? Do I need the panhard rod? Again, I don't do any road racing...
Thanks a lot guys. I would like to order my parts ASAP.
Altered Speed
3rd Times A Charm
Originally posted by goat678@January 28, 2006, 9:55 PM
i thought you had the WMS intake I dont know what u should get im a rookie
I never had the WMS...
You've been a member for 8 months. You are no longer a rookie!!!
If you drop your car 2" you really mess up your suspension geometry. If you're going to buy BMR springs, I'd suggest calling Jason at BMR and ask him what suspension parts he suggests to correct this if needed. You might have to get some adjustable arms or something to get your pinion angles set correctly by a shop. I'm no suspension expert either, this is just stuff I read. I know steeda only has a 3/4" drop because they said anything more than that on a stock suspension is bad. Call BMR they will know. I'm a noob on suspensions. I can't drop my car because the bumper would snow plow in the winter.
It doesn't matter what order you put those mods you listed on the car. They are all independent. If you're going to go with a 2" drop it might be a good idea to put the springs in before you get new wheels because those 18X9s might not fit.
if you look on BMR's web site, a lot of the different suspension products say stuff like "This mod is recommended for any type of racing and should also be performed if the vehicle is lowered to correct the rear suspension geometry. " or " This makes it necesarry to use an adjustable panhard rod when lowering your vehicle as it allows you to re-center the rear end"
Call BMR
Call BMR
IMHO, I would go for looks. These cars are way to nice to be trashed on the 1/4 mile strip. Go buy a old fox body to drag and keep the new one for show. UNLESS you're rich if something goes on it; then by all means go for performance. For me, I had plenty of Mustangs in my time with tons of performance mods in each one of 'em. Now I have a show car with four 1st place trophies to show for it since I bought my car back in April of '05. No matter which way you lean toward, do whatever makes you happy.
This is what I would do given your parameters...Go for the gears first, they will really wake your car up and give you seat of the pants enjoyment and will complement your performance mods well... Then I would go with the wheels and tires, they will add to your performance in that you will be able to corner better etc. and will dramatically change your car's appearance. Then lower it if you want...After the wheels and tires are on you might decide to not go so low...2" is a lot IMO. Your suspension mods should be done at the same time that you lower it as Dustin was saying so you can correct your geometry i.e. caster/camber etc...I would definitely recommend the lower control arms and the CHE lower control arm re-location bracket (bolt in model) as well as the adjustable panhard bar, then whatever you need to correct your geometry after lowering...I would lower it 3/4"s to an inch max. Just my 2 cent's, you have a good game plan.
Edit: I would bolt on the adjustable BMR LCA's & CHE relocation brackets before I did the gears then go as stated above...
you will also need caster/camber plates
other helpful mods form BMR include the strut tower brace and LCA relocation bracket.
i also REALLY enjoyed putting on my Eibach sway bars, probly the best dollar/improvement mod out there for handling (280 bucks for front and rear).
once again, id recommend doing the gears, then saving up and doing all the suspension stuff at the same time and having it installed professionally (even tho it seems like its an easy job to do in the driveway...)
It all depends on what you want to do.
If looks are your thing and spring is coming, get those rims ASAP.
Performance, hands down it has to be gears and a tune.
If you can, get the gears, tune and drop at the same time, at least you will have more control of the car with those gears going.
3rd Times A Charm
Thanks man! I will give Jason a call. I hope he can shed some light on this for me.
You think the 18x9s won't fit with the more extreme drop? The front is 1.5". I honestly have no idea???
Thanks for the advice man!
3rd Times A Charm
I hear what you're saying man, but it's easier said than done. I wish I could just buy another mustang and thrash it. But I want the best of both worlds.
I already wish I had gone all performance at first...
Thanks for the advice, I want to have some trophys too.
3rd Times A Charm
Thanks man! I've made my mind on the gears now! I will make an appointment on Mondaywhile at work, so my wife doesn't know. I told her that I wouldn't get gears 'til this summer!!!
I will order the LCAs and relocation brackets soon.
I was stoked about lowering it man...but I probably should wait until after the rims.
Thanks alot Justin! I appreciate it!
3rd Times A Charm
Originally posted by stkdidy@January 29, 2006, 2:50 PM
if not doing it all at once, i would first do the gears. after that, put in the springs and adj panhard rod (necessary with that much drop, trust me! i wish i had done it sooner). you could also throw on the LCAs then, but it is not needed as they just need to go on before going to the track. i recommend getting adj LCAs with polyurathane bushing on one end and rod end on the other, if you go rod ends only there will be a lot of noise.
Thanks for the response man! I wish I could afford to do it all at once!
I wanted your opinion for 2 reasons. What do you think about 4.10s as opposed to 4.30s for my M5 daily driver? Would you drop it that much if you had to do it again?
I will get the gears done first. Unless the UPS guy get's here sooner with the LCAs and brackets.
3rd Times A Charm
Originally posted by GRAYPNY@January 29, 2006, 2:59 PM
FRPP 4:10 gears and don't look back!
Thanks Rich. I figure you'd approve of the gears!!!
I found a shop in the San Jose area that'll do them for under 500 bucks. Parts and Labor! I think it's the same place Cleveland (Dan) got his done.
3rd Times A Charm
