Jlt oil separator
Old Sep 30, 2012 | 11:17 PM
Corstang427's Avatar
Jlt oil separator
This weekend I installed the oil separator on the drivers side. OMG was it a nightmare with a Paxton Novi supercharger. The radiator hose was in the way to clip into the intake manifold, the can wouldn't fit between the wiring with the Diablo MAF sensor, and I cant unscrew the can without taking off the clip on the cam cover. So basically a 1min job took 20min :/. Please any advice to fix would be great!
Old Oct 1, 2012 | 11:50 AM
05YellowGT's Avatar
Get some longer hose and move it , I have my moroso on the side of the CAI ...
Old Oct 1, 2012 | 11:56 AM
wheelman's Avatar
Just send me your supercharger and youll be all set.
Old Oct 1, 2012 | 01:32 PM
Could you show me more pics of your setup? Also what size hose and clamps did you use?
Haha I'll have to pass on that.
Old Oct 1, 2012 | 06:34 PM
Victorfriessen's Avatar
Yea im intrested in that as well,if you could post pics that would be great
Old Oct 2, 2012 | 09:04 AM
05YellowGT's Avatar
Get the same size hose as is on your can now , just get longer pieces and replace them so you can move it ...
Old Oct 2, 2012 | 12:38 PM
How do you clamp in ends on to the intake manifold end and the cam cover?
Old Oct 3, 2012 | 06:15 AM
05YellowGT's Avatar
I just looked at a picture of the JLT one , and I would just cut the existing hoses and splice some longer pieces in between so that you have longer lines. Then you can put it where ever you want. In the picture above you can see I cut the old hose with the connection to the cam covers and inserted the new hose into it. On the other end I used a T connector to splice into the line going into the intake , I have a MagnaCharger so my set up is different than yours.
Old Oct 3, 2012 | 10:11 AM
Ok sweet thanks, now I just need to figure out where to put the oil separator so it's not in the way.
14Glassback
Oct 4, 2015 08:52 AM
RoushRS3
Sep 29, 2015 08:03 PM
southern stang
Sep 26, 2015 04:19 PM
Jailbirdwatcher
Sep 25, 2015 06:39 AM
SterlingStunner
Sep 16, 2015 12:30 PM
