jba lonnnng tupe setup
Old Jan 10, 2006 | 02:00 AM
SonicGT's Avatar
those with the jba long headers and h-pipe, how many clamps did u get? and which one goes where?
just realized that i mispelled the topic name. meant to say "jba long tube setup"
stupid me
Old Jan 10, 2006 | 07:25 AM
Firedude's Avatar
I think I got four. I used the two wide, band clamps from the header to H pipe and the stock ones from the H pipe to the exsisting exhaust. I used one of the other basic muffler clamps that came in the kit in the middle of the H pipe where they come together.
Old Jan 10, 2006 | 08:09 AM
SonicGT's Avatar
i got one the looks like a ring, does that the one that holds the h-pipe togetherrr?
Old Jan 10, 2006 | 09:54 AM
Firedude's Avatar
That's what I did.
Old Jan 10, 2006 | 10:27 PM
Vegasjay's Avatar
I pretty much did the same...I used the wide clamps (JBA supplied) to connect the H Pipe to the headers and the stock clamps to connect the H-pipe to the axle back. I used the "U" clamp to hold the short "H" pipe connection together until I welded it. You will want to weld that short "H" pipe connection as it tends to leak with the "U" bolt.
Old Jan 10, 2006 | 10:47 PM
don_w's Avatar
My Dynatech headers came with clamps like this... they work exceptionally well on 2.5" slip fit connections!! You can get them at Jeg's and Summit.
Old Jan 11, 2006 | 08:56 AM
SonicGT's Avatar
yeah the jba hpipe came with two of those too. i just dont understand why is not just a one piece instead of a two piece
Old Jan 11, 2006 | 09:36 AM
Firedude's Avatar
Probably cheaper to ship.
Old Jan 11, 2006 | 10:25 AM
don_w's Avatar
I assume you mean the H-pipe is 2-piece. The X-pipe I got with my Dynatechs was 2-piece as well. And at first, I questioned why. But after installing it, I realized that having it a 2-piece design made it a ton easier to get it aligned. It gives you some left-right play to account for slight variances in the distance between the collectors (and/or cats). I am glad it was designed that way now.
K.A.I.N
13
Dec 26, 2015 01:29 PM
Airborne42
Sep 25, 2015 05:14 PM
Fred_Garvin
Sep 17, 2015 04:10 PM
MustangGTCS13
Sep 17, 2015 07:38 AM
1001yos
Sep 8, 2015 10:05 PM
