how much air are suppose to be the in tires?
Old Jan 7, 2006 | 02:29 AM
chowgp's Avatar
I have fanbades but i don't know how much air I'm suppose to fill them up to. I don't want to fill it up too much or too less. If anyone knows the pressure amount that would be helpful. Thanks in advance.
Old Jan 7, 2006 | 02:33 AM
Ponypower's Avatar
usually i run about 35psi, but check on your tire for the amount
Old Jan 7, 2006 | 05:28 AM
T Town Bobby D's Avatar
Check on your drivers side ....inside door frame plate, that will be the correct pressure.... not on the tire.
Old Jan 7, 2006 | 06:12 AM
KWMJ-KTP's Avatar
On the 18" Fanblades, the correct pressure is 32 PSI front and rear.
The spare should be 60 PSI.
Old Jan 7, 2006 | 10:27 AM
Giddyup's Avatar
I run at 33 lbs. front and rear...
Old Jan 7, 2006 | 05:00 PM
NHstang's Avatar
What he said. The label says 32 psi all around. That'll insure the tires will get the most life as well, as expensive as they are.
Old Jan 7, 2006 | 08:36 PM
Boltzman's Avatar
32 psi all the way around for me too
Old Jan 9, 2006 | 12:31 AM
chowgp's Avatar
I dunno what 32 psi equals to at the gas station air pumps. They have this meter and mines at 5 and a half. Anyone know what number it should be at?
Old Jan 10, 2006 | 09:37 AM
SpiderMan79x's Avatar
Why not the pressure that is on the tire?
Old Jan 10, 2006 | 10:06 AM
Kluski's Avatar
If I remember right, the pressure on the tire is "max." The pressure on the door is the suggest pressure for that particular vehicle.
Old Jan 11, 2006 | 11:01 AM
Stoenr's Avatar
100% correct
DrisStang
Sep 14, 2015 06:20 PM
Sep 8, 2015 10:45 AM
Omegaprime92
1994-2004 V-8
Sep 8, 2015 08:53 AM
OneCoolGT
Off-Topic Chatter
Sep 3, 2015 07:50 AM
