Issue with Steeda CAI
Old Jul 17, 2012 | 06:22 PM
sdsguy's Avatar
Hi all,
I got my 2008 Bullitt used and it came with BBK throttle spacers and a Steeda CAI. One day I was driving and noticed the hood tends to shake at speed (roughly 70MPH) from the front driver's side. I had my dad hop in and had him check it out from the passenger seat but there wasn't much of a shake.
My guess is that the heat shield sits up too high and doesn't let the hood close enough so air is pushing up the hood at speed. My first thought was to remove that rubber gasket that sits atop the heat shield and that might allow for better closure or i might try cutting out a piece of the heat shield that seems to be the high points.
Does anyone else with the Steeda CAI have this issue? Any other potential solutions?
Old Jul 17, 2012 | 06:32 PM
Does the hood close flush with the fender? That should be your guide as to whether the CAI is pushing the hood up.
Some Bullitt owners had to readjust the stops because of hood flutter at high speeds.
You wouldn't want to trim or remove the CAI gasket where it meets the hood liner because that's what insures you are getting cold air which is in large part where the extra 15hp came from over the GT (plus revised tuning and harmonic balancer to take redline up to 6500 over the GT's 6250). The hood liner was redesigned for the factory FRPP CAI. I assume the Steeda CAI meets the liner properly.
Old Jul 17, 2012 | 06:40 PM
ford20's Avatar
I agree with Charlie, try adjusting your bump stops and do not cut the rubber of the CAI. Granted I don't have the Bullitt or the Steeda CAI but I had the hood flutter also and I adjusted the bump stops and the shaking largely went away.
Old Jul 17, 2012 | 06:45 PM
sdsguy's Avatar
Just to clarify, bump stops are??
Old Jul 17, 2012 | 07:25 PM
B1GP1MP1N's Avatar
They are pieces of threaded rubber on the front corners of your fenders under your hood. They are threaded to be adjusted up or down. You turn them right to lower them and left to raise them. For the problem you are describing I would assume you would lower them. (Someone correct me if that's incorrect)
Old Jul 17, 2012 | 09:48 PM
wallace's Avatar
I have the Steeda and it's been perfect the previous 6yrs, HAD a throttle body spacer. I removed it for two reason, it didnt wrk and the cai didn't fit properly with it on the car
Old Jul 17, 2012 | 10:25 PM
texastboneking's Avatar
Bear Eats King...
Bear ****s Bone
Lol @ throttle body spacers
Old Jul 17, 2012 | 11:23 PM
sdsguy's Avatar
The hood on the drivers side just sits a bit higher than the passenger side, I'm talking about a few millimeters or so. I'll try the bumper stops. I unfortunately don't have the oem parts to see if that alleviates anything
Old Jul 18, 2012 | 05:22 AM
05YellowGT's Avatar
I have the Steeda CAI with an aftermarket hood and I had to trim my heat shield so it would clear the hood. You have to be careful you don't trim too much off , so that you'll still have a good seal with the velocity stack. I then went to the auto parts store and got a new rubber gasket to put back on ...
Old Jul 18, 2012 | 12:31 PM
Flagstang's Avatar
Spam Connoisseur
I got هَبوب‎ed
take off the throttle body spacers.. it doesnt do anything.
Old Jul 18, 2012 | 12:36 PM
Bear Eats King...
Bear ****s Bone
Looking for the *like* button
Old Jul 18, 2012 | 01:17 PM
05YellowGT's Avatar
That's not true , it gives you guy's something to rag on him about
Old Jul 18, 2012 | 01:18 PM
Flagstang's Avatar
Spam Connoisseur
I got هَبوب‎ed
no we are helping
Old Jul 18, 2012 | 03:29 PM
sdsguy's Avatar
Just for reference previous owner had that on. I've thought about taking it off and seeing if maybe that created any issues with the way the CAI is sitting.
Old Jul 18, 2012 | 03:32 PM
Bear Eats King...
Bear ****s Bone
That's a good idea
Old Jul 18, 2012 | 11:39 PM
sdsguy's Avatar
I feel like an idiot. Wasn't a throttle body spacer but a bbk throttle body. I was off today so I figured I'd clean up the throttle body. FYI bbk makes it super difficult, too many different sized nuts and and various torx screws.
I made the bumper stop a little lower, still have some hood flutter. The hood sits lower on the bottom but still around where the cai is. I can see in the hood where the rubber gasket hits, seems like maybe an 1/8th of an inch too high.
Old Jul 21, 2012 | 09:06 AM
tj@steeda's Avatar
SDSGUY,
Glad you were able to find the root of the problem. If you ever think their is an issue with a Steeda part, please call us directly. We can give you the best advice since we know these cars inside and out.
Please let me know if you have any additional questions? If your problem is solved and your happy, then case closed!!
Best Regards,
TJ
Feb 10, 2017 07:12 PM
Sep 16, 2015 06:44 PM
Grabber5.00
Sep 13, 2015 06:53 AM
Sep 10, 2015 12:44 PM
Sep 8, 2015 10:45 AM
