Intake vs CMDPs
Old Aug 22, 2012 | 06:03 PM
muscledom's Avatar
Intake vs CMDPs
I wanna get a couple more bolt ons before I get dynotuned. Maybe a throttlebody, definitely an intake or CMDPs. I know the intake will delete the charge motion plates but is there any real gain from the intake otherwise? Just trying to determine whether it's worth the extra $350. Thanks guys
Old Aug 22, 2012 | 08:09 PM
JerryG2163's Avatar
If I remember correctly, you have cams installed on your car right? If so I think you can probably expect a gain from the combo of the cams and intake working together (I think). Somebody correct me if I'm wrong, but I'm pretty sure that's the best way to maximize gains with cams. The only other piece would be the heads which can be a pretty expensive route as a Bolton
Old Aug 22, 2012 | 08:55 PM
muscledom's Avatar
Yea I have cams and full exhaust. I'm just not sure how much better the flow will be with a whole new intake compared to just getting the delete plates, which from what I understand get rid of the majority of the resistance (the butterflies in the stock plate). But you're right, the better the cams breathe the better they work.
Old Aug 23, 2012 | 11:32 AM
Taxman72's Avatar
If you have cams and long tube headers, you'll see a really nice gain from the intake vs. the CMDP's.
Old Aug 23, 2012 | 11:51 AM
muscledom's Avatar
I'll probably look for used intakes, been thinking about getting a roots blower after its paid off so I don't wanna go crazy. Well see what happens lol
Old Aug 23, 2012 | 11:59 AM
Taxman72's Avatar
I just got one for $475 from somebody on another forum I'm on. That's what they normally go for. C&L's go for about the same.
Old Aug 23, 2012 | 12:21 PM
muscledom's Avatar
No doubt. I'll have to keep on the lookout.
Old Jan 16, 2013 | 06:53 AM
metroplex's Avatar
MMFF tested the 4.6 3V with 8 different combinations, and the best one was the one without the FRPP intake:
http://www.musclemustangfastfords.co...g/viewall.html
There was significant drop in sub-5k power and torque even with the 3 Stage CNC heads and Hot Rod Cams with more gains in 6000-6500+ RPM. The way I see it, unless your engine is going to stay operating in the 6000+ RPM range, the FRPP intake isn't that great of a mod. Look at the link above, Setup 7 is the engine with the FRPP heads and FRPP hot rod cams. Setup 8 is the engine with the FRPP heads/cams/intake. I plotted the data in Excel and looked at the area under the curves and not just the peak values. Setup 7 is worth about +40 hp over stock. But that convinced me not to consider the FRPP intake.
Antigini-GT/CS
Oct 5, 2015 09:43 AM
RoushRS3
Sep 29, 2015 08:03 PM
Christopher Fox Wallace
Sep 26, 2015 11:55 AM
