installing steeda pulleys, where is the new alt. bolt go?
Old Feb 18, 2006 | 07:10 PM
traffic142's Avatar
Thumbs down
I was looking at the install and double cking the torques. Where is the new alternator bolt go? There is the old bolt I assume in the box from the mechanic. Did he change it out?
I looked at the alternator, there are 2 bolt/nuts on the bottom portion, closest to the pulley (at the 5 adn 7 oclock location. The one on the right as you face it that almost rubs the pulley and belt. It is painted the same color as the alternator. [img]style_emoticons/<#EMO_DIR#>/headscratch.gif[/img]
So can anyone show me a pic or help me find the location of it to make sure? [img]style_emoticons/<#EMO_DIR#>/worship.gif[/img]
I thought I read that not changing it out causes a problem. with a 5 speed how do you keep the pulley from turning after the final torque is applied ( the 90 degrees) I got it in 1st gear. I noticed on the pulley there are 180, 270, 90 on it. is that you reference in pulling the final degrees????
HELP [img]style_emoticons/<#EMO_DIR#>/banghead.gif[/img] [img]style_emoticons/<#EMO_DIR#>/banghead.gif[/img] [img]style_emoticons/<#EMO_DIR#>/banghead.gif[/img]
Old Feb 18, 2006 | 07:41 PM
thump_rrr's Avatar
<div class='quotetop'>QUOTE(traffic142 @ February 18, 2006, 9:13 PM) Quoted post</div><div class='quotemain'>
I thought I read that not changing it out causes a problem. BTW all my torques were correct.
[/b][/quote]
5 O'clock bolt must be replaced
Old Feb 19, 2006 | 05:33 AM
traffic142's Avatar
ok, how? there does not seem to be a way to replace it. the existing bolt has a nut on it and I felt around and no head on the other end. (it does not seem to be a real bolt at all). And the replacement bolt has not nut or washer. A little more help.
Old Feb 19, 2006 | 06:05 AM
thump_rrr's Avatar
<div class='quotetop'>QUOTE(traffic142 @ February 19, 2006, 7:36 AM) Quoted post</div><div class='quotemain'>
[/b][/quote]
It's a stud which can be unscrewed.
First remove the nut and then if you look closely the stud has a hex head which can be used to remove the stud.
Old Feb 20, 2006 | 08:41 AM
traffic142's Avatar
thanks for the help thump rrr
Got it. had to use the alt. nuts as jam nuts to get the stud out, but it is cool now. I could tell it was rubbing on the top back side of the pulley it was shiny on the rear lip just a little.
Thanks again
Jim74656
May 1, 2023 02:15 AM
Ecostang
Nov 3, 2022 08:50 PM
glo106
Aug 11, 2015 08:29 AM
ustabawannab
Aug 5, 2015 08:32 PM
Ecoboost
Jul 25, 2015 06:32 PM
