Installing BMR LCAs
I am installing non-adjustable BMR LCA's w/poly bushings this weekend. I read a thread here awhile back detailing the installation but I can't find it when I search.
I have 2 questions:
The install instructions say to remove the wheels and lift on the axle. Can they be changed without removing the wheels by using a lift that keeps the car's weight on the wheels?
I also read somewhere that the bolt torque requirements was other that the 75ft lbs. that the instruction state.
Thanks for the help.
I have 2 questions:
I'm sure you could install them with the wheels on, but much cursing involved due to the location of the bolts. As far as the torque, I did mine to the 75ft lbs and haven't had a single problem. I really would recommend taking the rear wheels off though since you'll have much easier access.
Since it sounds like he's doing it on a lift, then maybe leaving the wheels on wouldn't be a big deal.
PM me, I just did it yesterday. I also have a cheat sheet I can email you with photos.
I can pass along a few tips.
If you have access to a lift, use it. I used jack stands and put them under the axels. This kept it under tension for torquing it down.
Remeber you have to disconect the E-brake cable .It goes thru the factory LCA.On both sides.
<div class='quotetop'>QUOTE(1SG @ April 19, 2006, 11:52 AM) Quoted post</div><div class='quotemain'>
[/b][/quote]
the tech manual states 129 ft pounds.
[/b][/quote]
9/10/15 12:44 PM
