Installing BMR LCAs
Old Apr 19, 2006 | 12:49 PM
WB2005GT's Avatar
I am installing non-adjustable BMR LCA's w/poly bushings this weekend. I read a thread here awhile back detailing the installation but I can't find it when I search.
I have 2 questions:
The install instructions say to remove the wheels and lift on the axle. Can they be changed without removing the wheels by using a lift that keeps the car's weight on the wheels?
I also read somewhere that the bolt torque requirements was other that the 75ft lbs. that the instruction state.
Thanks for the help.
Old Apr 19, 2006 | 01:36 PM
Dysan's Avatar
I'm sure you could install them with the wheels on, but much cursing involved due to the location of the bolts. As far as the torque, I did mine to the 75ft lbs and haven't had a single problem. I really would recommend taking the rear wheels off though since you'll have much easier access.
Old Apr 19, 2006 | 01:51 PM
don_w's Avatar
Since it sounds like he's doing it on a lift, then maybe leaving the wheels on wouldn't be a big deal.
Old Apr 19, 2006 | 02:54 PM
WB2005GT's Avatar
Thanks, I'll try it with the wheels on and if it's a problem i'll take them off.
Old Apr 19, 2006 | 03:11 PM
MaverickMLFD371's Avatar
Had no problems with wheels on! Just let the axle hang and you'll have no problems....
Old Apr 19, 2006 | 05:48 PM
traffic142's Avatar
PM me, I just did it yesterday. I also have a cheat sheet I can email you with photos.
I can pass along a few tips.
If you have access to a lift, use it. I used jack stands and put them under the axels. This kept it under tension for torquing it down.
Old Apr 19, 2006 | 06:00 PM
mikem's Avatar
Remeber you have to disconect the E-brake cable .It goes thru the factory LCA.On both sides.
Old Apr 19, 2006 | 10:07 PM
nonsensez9's Avatar
<div class='quotetop'>QUOTE(1SG @ April 19, 2006, 11:52 AM) Quoted post</div><div class='quotemain'>
[/b][/quote]
the tech manual states 129 ft pounds.
Old Apr 19, 2006 | 10:50 PM
kampendmk's Avatar
it`s easy 57 and i did it
Mr. V
Dec 24, 2016 02:57 PM
Sep 10, 2015 12:44 PM
jim010
Sep 7, 2015 02:40 PM
SMOKE46
Sep 6, 2015 09:40 PM
